Question about Bissell Powergroom Pet Vacuum
Belt keeps breaking, but motor turns easily by hand on bissell powergroom, burnt rubber smell as well.....
Changed belts, took it apart but unsure how to check the motor or what i'm looking for to determine why it will turn by hand but the belt breaks when you turn it on....
  • 389 Answers
SOURCE: bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Posted on Mar 08, 2009
  • 3 Answers
SOURCE: brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Posted on Jul 28, 2009
VacuumRepair
  • 438 Answers
SOURCE: Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
http://www.govacuum.com/biclandpobar.html
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
http://www.fixya.com/support/p49887-bissell_6594_powerforce_bagless_upright#manuals.
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
GoVacuum
Posted on Mar 23, 2010
SOURCE: roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Posted on Apr 03, 2010
BissellCSR
  • 276 Answers
SOURCE: loses power & smells like burning
If the belts are intact and the brush roller is rotating and the problem persists, the machine should be inspected internally at an authorized Service Center. Go to www.bissell.com under the Customer Support tab and enter your zip code under Service Center search.
Posted on Jul 06, 2010
I need to know what belt is used on the bissel powergroom
The Style 2 Belt fits Bissell Powergroom Models 35301, 35351 & 35352.
I hope this helps.
Oct 19, 2012 | Vacuums
Bissell vacuum model # 4104 Powergroom has loud screeching noise when turned on
most likely the belt check for obstruction on agitator(spining brush on bottom) 1st.if there is no obstruction you will need to remove bottom cover(usualy 4 to 5csrews to inspect rubber belt&replace if needed bypulling agitator remove belt&replace.belt may be purched at most stores selling bissel.
Apr 10, 2012 | Bissell Vacuums
Smell of burnt rubber
Hi, the smell of burnt rubber is an indication of a broke or stretched power head belt. The belt can be accessed usually form the bottom. Chrs
Feb 21, 2011 | Bissell 6594 PowerForce Bagless Upright...
I took the vacuum apart and cleaned it. Now there is an odor coming from the round filter and the vacuum is not picking anything up.
  • hi there
  • Does the odor smell like burnt rubber....if so you may have burned out the belt which is common. The filter can smell if you have pets and the machine will blow the odor back in to the room after the filter gets older.Check to see that the roller brush is spinning when it is turned on if not shut it off and try to turn it manually with your hands. If it turns very easily the belt gone if it is almost impossible to turn you need a new roller brush.You can replace the filter to help with the smell but if it is the belt you smell it will go away in time. Also make sure that you have the container on perfectly as if it is not it will not create a perfect seal and you will have very little suction. The other thing you can check is the hose to see if the suction is good through it. If the hose has good suction then the power head may be plugged with something and you will need to get a screwdriver and take the bottom plate off the same way as if you were changing the belt and then you can look for a blockage as well as access the belt and roller brush. I hope this was helpful to you ...good luck
Oct 13, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My brush roller isn't spinning on my bissell powergroom vacuum
You belt has probably broken or it has stretched to the point where it won't turn the brush against the resistance of the carpet. You need to change the belt. Below are the two possible belts you could need. Check and see if yours is a PowerGroom Pet (it will say on the vacuum) or just the regular PowerGroom model. Here are the belts:
Regular PowerGroom Replacement Belts
PowerGroom Pet Replacement Belts
Oct 30, 2009 | Vacuums
Eureka 2961 BVZ no suction, burning smell
I have the same vacuum. The burning smell is letting you know that your belt is either broken or about to break. I have had mine for a year and have had to replace the belt 5 times. Now I have to replace the brush roller 'cause it broke under normal use. My next vacuum will be a Dyson Ball.
Jul 05, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Belt smells burnt
If the belt has melted then there's something obstructing between the brush, belt and dust channel. Check that the endof the brush roll is completely clean, check that the brush roll rolls easily with your hand (obviously don't plug it in or switch it on when repairing/inspecting) If you can locate the motor shaft pin make sure that it rolls easily - if not then the motor may have seized up which will need professional repair. Also check that the filters are clean and the hoses are clear.
Mar 22, 2009 | Dirt Devil M085850 Featherlite Bagless...
Bissell Powergroom Pet Vacuum Logo
116 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
