Question about Kitchen Ranges
Jenn Air Fault Code F9-2
I am having the same problem at a friends house. I got the f9-2 code. I turned the motor so where the lock is open and reset it. Then put it into clean mode and then f9-1 came up. Next I pulled the harness off and checked for voltage after I reset it. I could hear the little relay on the board clicking but I never got a voltage reading which tells me its the board... The code guide I found though says replace the motor assembly. I checked both AC and DC voltages just in case and never got a flicker of voltage. Is it the board then? Just need some reassurance before I invest in purchasing parts.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Jan 19, 2013
  • 2 more comments
  • Nathan Jan 19, 2013
    jes9800aab
  • Richard Roth
    Richard Roth Jan 19, 2013
    F9-2 Door lock will not release ( Check wire connections. If ok, replace motorized door lock. Here is the part to order.http://bit.ly/13PVndE
    Yes, I know, I found that as well. If you read my original post I go into further details about how I checked the voltage supply to the motor and there was nothing so I don't think it is the motor. Any other thoughts or should I just follow those directions blindly?
  • Richard Roth
    If you are not getting any voltage then the ERC will need to be replaced. Here is that part to order.http://bit.ly/WOAyZo The part comes with a 365 day, any part, any reason return policy.
3 Suggested Answers
  • 7 Answers
SOURCE: Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Posted on Mar 15, 2009
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Posted on Sep 17, 2009
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Have a jenn-air gas range with a f9 code come on with oven is use. What is this code.
Hi There
I have found this code for you and hope this helps you.Let me know how it goes.
F9 Door lock safety circuit on power relay board sensed Replace power relay boardThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
Feb 18, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
F9 code
says F9, is a problem with door lock saftey circuit. replace power relay board
Mar 01, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven door locked, F9 indicator signal
Monster, F9 is the door locked error. Try turning off the breaker for 30 seconds and see if it resets. If not, you are going to have to get a coat hanger, make a U at one end and slip it between the door and latch from the left. Once you feel the latch, give it a tug and the door should open. Try resetting the board again with the door open and see if the lock mechanism homes. If not you will have to check the cam and switches for problems. Catriver..post back.
Oct 05, 2006 | Jenn-Air JER8855 Electric Kitchen Range
Kitchen Ranges Logo
131 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
