Question about Kitchen Ranges
Ignition wont spark - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Model number?
Posted on Jan 19, 2013
  • whangamatara
    whangamatara Jan 21, 2013
    Not sure of model but the ignition button has a AA battery inside so when you push it it is supposed to create an electronic spark but isn't
No ignition spart
what make ,model an year vehicle. What type ignition system , coil on plug , DIS -waste spark ignition etc... Is there B+ voltage to the the coils , ignition module etc.... when you turn the key to the run position does the check engine light turn on ? There are a lot of good diagnostic videos on you tube .
Dec 17, 2015 | Cars & Trucks
MY WILDFIRE WF 1200 HAS VERRY LITTLE SPARK WONT START
Check for faulty spark plug, fouled spark plug, loose or disconnected wires, broken or shorted spark plug wires, faulty ignition pulse generator, faulty ignition coil, faulty engine stop switch, faulty ignition control module or some others.
Work through these from the start
Oct 16, 2014 | Motorcycles
03 hyaudai santa fe 3.5 got stuck in the snow several times stopped running thought i was outa gas changed plugs wires boots battery added gas ,,wont start getting fuel she tries just wont start
Aw, were you guys out spoofing around? Maybe moisture got into some ignition electrical connections. If it has a distributor, make sure that the inside of the distributor cap is dry. Check for a blue, snapping spark on a spark plug wire end to see if it is an ignition problem. If no spark, you will need to diagnose the ignition circuit or system.
Apr 21, 2014 | 1993 Toyota Camry V6
Spark plugs wont spark car wont start
ignition coil and the ignitor assembly within the distributor. The ignitor assembly grounds the ignition coil at a frequency to saturate and trigger the ignition coil. The coils fail relatively often. good-day!!
Jul 29, 2011 | 1991 Geo Prizm
I have a 2001 dodge durango 5.9lL and it wont start. I can hear the fuel pump when I turn the key half way but when I turn it all the way the starter turns but the engine wont turn over
It sounds like you are not getting spark from the spark plugs. The ignition coil controls the spark. The crank sensor also controls the spark. If I had to guess I would say test or replace the ignition coil. If tests okay i would do a resistance test on crank sensor. But at my shop I have seen many Ignition coils go bad.
Oct 25, 2010 | Dodge Durango Cars & Trucks
Falcon ED wont start. No spark. Just replaced
check all the fuses 10 amp is pretty common same as radio fuse
Jun 07, 2010 | Ford Fairmont Cars & Trucks
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Will start up with no problems. Let sit for a hour and bike will crank but will not start. I am not getting spark to the plugs but that is as far as I have gotten
Sounds like once the ignition is hot it wont supply spark need more info but .. shoot freon on ignition when it wont spark does it work now?
Aug 11, 2009 | 2004 Harley Davidson FXST - FXSTI Softail...
2001 Ford Focus stopped running while i was driving and wont start. Makes a churning sound but no power is going to engine. I changed the ignition coil, still wont turn on. Any suggestions?
Can you explain more so I can help. What do you mean still wont turn on, engines doesn't start or starter motor doesn't turn. Have u taken out a spark plug and connected it to the cable put the end of the spark plug to a ground and make someone turn on the engine for a few seconds you should see some blue sparks. Carefully use gloves. If no sparks, spark plug is bad next thing to check instead of putting the spark plug in the cable put Philips screwdirver put the screwdriver near a ground not touching about one inch make someone turn the engine for a couple of second you should see the spark jumping from the screwdriver to the ground, If there are no sparks ignition coil or spark plug cables are not good. But u say u changed ignition coil so maybe your cables are not good. There is a connector near the ignition coil disconnect it and turn ignition switch on measure the voltage you should have in between 12vdc + or - .5 vdc if no voltage present there is a blown fuse, Check for it
Jul 23, 2009 | 2001 Ford Focus
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
