Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wd63 washer dryer when complete when i open the door alot of hot steam comes out
When the dryer has finished the drying stage everything seems to be working ok even going through the cooling down stage. when i open the door alot of hot steam comes out and the clothes are red hot and are still slightly damp. An engineer has been out but he reckons there is nothing wrong with it. Any ideas thanks sharonj1969
Your water supply to the machine has been turned off, or the triplewater valve has gone open circuit on the condensor solaniod if you have a multimeter you can test the valves unplug the machine from the mains and turn the cold water supply off , take the back panel off take 2 wires off at a time and test each solanoid they should read around 3800 ohms if you nget no reading on 1 of the solaniods thats you problem change the complete valve. good luck
Posted on Jul 17, 2007
SOURCE:
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
HOTPOINT BWD129 CAN'T GET IT TO TURN BACK ON WHEN IT FAILED HALF WAY THROUGH A HOT WASH
check if you splash a lot of water specially at the center of the unit. there is this water sensor that would turn it off once this sensor is wet.
do you have any error codes?
tnx 4 using fixya,
drcool
Oct 06, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door won't open for Washer Dryer
WHAT HAS HAPPENED HERE IS THAT IS THE INTERLOCK HAS SHORTED AND BLEW THE FUSE AND THE REASON WHY THE MACHINE WORKED CAME BACK ON IS BECAUSE THE INTERLOCK HAS NOW OPENCIRCUIT AND THAT IS WHY THE DOOR WILL NOT OPEN JUST REPLACE THE INTERLOCK
Apr 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
126 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
