Question about Dell Ultrasharp 1801FP (Midnight Grey) (Gray) 18.1" LCD Monitor
Dell ultrasharp 1801fp won't turn on at all, no power
The monitor will turn not turn on, tried different power cords and still no response. However when pulling off the ac power cord plug, there is a sudden flicker of the screen (~0.5sec) then the monitor remains life less.
5 Suggested Answers
SOURCE: Monitor Flashes Colors when system powered down
Looks like the Burn-in mode is turned on. See here:
http://www.dellcommunity.com/supportforums/board/message?board.id=dim_monitor&message.id=70187
Cecil Thomas
Posted on Jan 14, 2008
  • 9 Answers
SOURCE: Power Cords
One.
Posted on Feb 03, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I need power cords for my monitor
The monitor needs a power cord and a signal cable. The power cord is a standard 3-prong detachable cord just like the one on nearly every desktop computer and many other electronic appliances.
The signal cable may be one of two types, depending on your computer's video connector. The monitor has connectors for both VGA (a D-shaped connector with 15 pins) and DVI (a rectangular connector) inputs. You need a cable with whichever type of connector fits your computer.
You should be able to find the power cord at Radio Shack, any of the big office supply places, or retailers who sell computers. The signal cable may be available there as well, or you can order from a number of online vendors.
The monitor also allows you to plug in a USB cable from your computer so you can plug in USB devices like a keyboard or mouse. For that you need the same kind of USB cable you would use to connect a printer.
You can view or download a copy of the monitor user's guide at Dell's site here:
http://support.dell.com/support/edocs/monitors/1704fpt/EN/index.htm
If this solution has been what you need, please take a moment to rate it. Thanks for asking here!
Posted on Feb 21, 2009
Vivektj
  • 55 Answers
SOURCE: Dell LCD. Will show desktop for less than 1 sec
It’s very likely your monitor has failed. Most Dell monitors have a 3 yearwarranty, so if you got it before three years, you could get it replaced bycalling Dell. If you got the monitor with the computer, you can check yourwarranty online from with your computer Service Tag fromhttp://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen .If you bought the monitor separately, you would need an Order Number orCustomer Number for the purchase, or you could call Dell support and they couldpull it out with your registered phone number. Dell would also need the serialnumber (starting with CN XXX..) from the back of the monitor.
Monitor User guide for 1905FP available at http://support.dell.com/support/edocs/monitors/r83546/EN/index.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Posted on Mar 26, 2009
  • 6771 Answers
SOURCE: Where can I get a power cord for a Dell Ultrasharp
The computer repair store nearest you or tv shop should be able to provide you with the power cord. They are standard in the industry.
Posted on Dec 30, 2010
How do i adjust the brightness on a dell 1801fp?
Play with the arrow up and down on the monitor.
Terry
Jan 14, 2015 | Dell Ultrasharp 1801FP (Midnight Grey)...
Power led blink once
Its most likely a simple loose connection with the HDMI or VGA cable in the back.
Jul 29, 2014 | Dell Ultrasharp 1801FP (Midnight Grey)...
Drivers for\ dell 1801FP ultrasharp monitor
There are no drivers, Windows should install them automatically
Jul 09, 2014 | Dell Ultrasharp 1801FP (Midnight Grey)...
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Where can I get a power cord for a Dell Ultrasharp Monitor # Mx-09j367-47605-31l-a5m7
Dec 30, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Won't power up
You can try fixing the board down to component level or spend about $25 on the replacement board.
http://www.lcdrepair.us/1801fp-inverter-power.html
Or learn how to troubleshoot the problem:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Nov 30, 2010 | Dell Ultrasharp 1801FP (Midnight Grey)...
Dell w3206c no turn on
Biker,
The power cord is probably loose.
check the cord where it connects to the monitor and push it in to re-seat it.
Nov 11, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Will not turn on. i have tried different outlets different cords and different computer.. it will not turn on
There are no "user-serviceable" parts inside a LCD monitor.
So, all you can do is to take it to a qualified TV/video technician, for trouble-shooting. Or, just responsibly recycle it, and buy a new one. Some stores may give you a "trade-in" on the old one, because the LCD screen itself may be OK, i.e., the problem is in the "electronics".
Jun 30, 2009 | Dell UltraSharp 2007WFP Monitor
No power to 1801fp
Less than 5 bucks. Also look at the inverter board, and underneath the board it goes to Yup, common as dirt inverter could be swapped in, or - You could cut off a +12volt and +5 volt lead/connector for disk drives from a dud power supply , drill a hole, and power it externally from any **** no name power supply. Of course, replacing all electros under 100uf may get you going for under a dollar. Canberra
Jul 03, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell Ultrasharp 1801FP (Midnight Grey) (Gray) 18.1" LCD Monitor Logo
218 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
