Question about Kenmore Elite 45986 Front Load Washer
F11 error kenmore He4t
I had this problem before and there were socks in the pump...I was not home when he fixed the problem...does anyone know how to find the pump on this machine I would like to do this myself if I can...
  • 640 Answers
Take bottom panel of theres 3 screws,,,the pump filter is right in center ,,just twist it off,,put a little bowl down there always a little water in pump...onthejob
Posted on Jan 28, 2009
Washing machine keeps stopping
E20 not draining error. Since you checked filter at bottom right corner for blockages, then maybe the drain pump has gone faulty or something jammed in it. You can also check the drain hose for kinks or blockages. You can try blowing out any cloggs in the machine with an air compressor.
Please let me know if you need any further help, otherwise good luck on fixing your problem.
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Error code F11
F11= Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. The board needs to be replaced. Here is a link to it.
http://www.repairclinic.com/PartDetail/Circuit-Board-or-Timer/1059575
Nov 25, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer showing error code SUD
any f35? or is it just sud?
is it green?
if it is just sud and happens towards the end of the cycle take your kick panel off....3...7 millimeter screws or t15 torques whatever you have will work.
twist off the pump catch see what's inside...if there is socks and debrie you fixed your problem.
if it happens at the beginning you have a bad pressure switch usually happens on the steam washers....what color is it?
May 04, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have a Kenmore Elite HE4T washer and im getting a F11 code
Search the web (including the FixYa site) for F11, HE4T, relay, solder, F D/L or some combination of those keywords and you'll find several existing posts, blogs, or how-to articles explaining how to resolve the F11 error (e.g. http://he4tf11.blogspot.com/). There are tons of theories on why the F11 occurs, but I've fixed it on our HE4T twice now and the root cause both times was the relay that transfers power to the door lock and shaky solder connections on the relays that transfer power to the motor controller. If you're handy with soldering equipment, pull out the main controller board (under the top cover near the back in a plastic box). Replace the relay that is described in most of the various web posts/articles about this problem, and re-solder each one of the leads on the larger black relays. The relay that burns out and must be replaced is available for about $1.50 each from Allied Electronics (alliedelec.com search for G5LE-1-DC12 or 821-2208). Order a few extras because it will most likely burn out again after a few more years. Be absolutely sure that you have _solid_ solder joints on each and every one of the leads on every relay before putting the board back in the washer.
While you have things open, you might save yourself some musty smelling clothes by pulling the internal drain hose off and cleaning it out with a scrub brush that's small enough to pull back and forth through the hose with some string or wire. Detergent residue cakes up and clogs that hose, the drain pump trap, and the external drain hose. Cleaning all of them will help fully and quickly drain the tub during a wash cycle. Remove the panel beneath the door to reach the drain pump. The lower end of the internal drain hose clamps to the drain pump and it's a tight fit to reach the clamp. Be sure it's back on securely if you don't want a floor full of water. The drain pump has a cap on the front that you can remove to clean out the trap.
Sep 08, 2009 | Kenmore Elite 45986 Front Load Washer
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 05, 2009 | Washing Machines
Kenmore HE4T Elite F06 problems
Given I had purchased the Extended Warranty, Sears replaced the washer. So, we will see how this one works.....
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
180 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
