Question about Dishwashers
GE Dishwasher will not fill with water
I have a 6 year old built in GE dishwasher. Today I went to use it and the water would not fill. YIKES. I need this appliance. Do you think I can fix it?
  • paciobj Jan 26, 2009
    OK. I'll do that. Will there be some type of instructions on how to do this?
  • 979 Answers
You probably have a bad water valve. It is not expensive to replace. About 25-30 dollars. Go to an appliance dealer and tell him the model and he will sell you the part. It is fairly easy to replace too.
Posted on Jan 25, 2009
  • Bill Dickerson
    Bill Dickerson Jan 26, 2009
    Yes, there will be a diagram with the new part that will explain it. I believe specifically the part will be called a solenoid. It does act by an electrical impulse that shuts and opens the water valve. The solenoid actually opens and shuts the valve. When you go to the appliance dealer, tell him about the problem and he will give you the correct part. When mine went bad, it was actually the solenoid that was bad. Good luck and let me know how it turns out.
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
The dishwasher starts to fill wwith water then stops but
Most likely faulty door switch
Slght possible the control panel is shot but door switch is cheaper and just as common
Aug 27, 2009 | GE 24 in. GSD4020Z Built-in Dishwasher
GE Dishwasher fills with water but does not "spray water" on dish
Here are a few things that might help you out, first is you could have a bad heating element in your dish washer, when it fills with water it has to reach a certain temperature before continuing to the next cycle, next thing is you could have a bad thermostat, or your timer is defective.
Mar 16, 2009 | Kenmore 16522 Built-in Dishwasher
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Nov 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
145 people viewed this question
Top Dishwashers Experts
