Question about Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
One long beep followed by three short after startup
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
Three beeps is a RAM issue. You need to replace the RAM.
Posted on Jan 19, 2013
Gateway wont startup. One beep followed by two short
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Nov 12, 2013 | Gateway GT5678 Desktop PC
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
Getting a single beep upon startup, no video signal going to monitor.
One beep means everything posted right
I would start with the video card and pull
it out of socket then reinsert it you could
have a bad card or bad cable or the
mother board cant handle vcard
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jan 14, 2011 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
On startup it beeps and wont startup. i hit F12 and it works fine now. thats all i did. so what could be the problem? i've already replaced a power supply about a year ago. and also my dvd player is kinda...
On startup beep how many beep do you hear?
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Hope it Help you out ^_^
Jun 29, 2009 | Dell XPS 200 PC Desktop
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
Laptop does a long beep, followed by two short beeps.
One long followed by two short beep IS a video error. However, your model laptop does not have a separate video card. The only fix is to replace the mother board. Here is the service manual that will show you how to take apart the laptop and even give you the part number you would need to replace the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 07, 2008 | Computers & Internet
Sony VAIO VGC-RC110G (VGCR110G) PC Desktop Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
