Question about Frigidaire FTF530FS Front Load Washer
Transporting a washer
I have a 1999 Whirlpool washer (and dryer) that I want to donate. Can I lay the washer on its side or its front so it will fit in my van? I know there are problems with older models leaking.
  • Frigidaire Master
  • 3,463 Answers
Remove the top cover, and put plenty of packing down both sides to prevent the inside parts from moving about, this way it will be o/k to transport it on it's side.
Plz rate my solution.
thanks.
Posted on Jan 25, 2009
Whirlpool WTW4900BW1 Washing Machine Loud Banging on spin cycle.
Transporting a washing machine in any position except upright can be fatal. The reason? The original packing material is no longer in place.
May 16, 2017 | Whirlpool Washing Machines
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Wed9270xws dryer has water in drum
Check that u can hear pump running if all u hear is a humming or nothing the pump is blocked up and needs cleaning the only way 2 do that is lay machine on its side and remove the hose and un screw the pump casing and remove the blockage if after that the pump still doesn't run then u need 2 replace it
Sep 28, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Should the dryer be placed on the front to make it easier to take the back off? That's what a repair person did and when they turned it back on it made a serious screaching noise.
There's no such instruction from the manufacturer to lay the dryer on its front when removing the back panel. The back panel can be easily removed with the dryer in upright position. Only leaning the dryer a few degrees is advisable by propping up the bottom edge, not laying it on any side, when access to the inside of the dryer is necessary. Otherwise, the internal moving parts will likely dislodge and cause problems like yours.
Mar 22, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I am looking to buy a used 4 year whirlpool duet washer and dryer. Do you need transport bolts to move either? Also what capacity is the washer and dryer
The transport bolts are required to be installed before transporting the machines. This is to support the suspension system to prevent damage to the machines during transportation.
The washer has a capacity of 9.0 kg or 19.8 lbs with a volume of 3.7 cubic feet. The dryer's capacity is 7.0 cubic feet.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Gearcase oil leak by laying on its side - Problem?
There is a breather hole in the top of the gearcase. Yoy probably had some leak out through there when you laid the washer over. If it was not over to long you will probably be ok. there is no way to replenish the oil it would require replacing the gearcase.
Apr 07, 2008 | Washing Machines
Whirlpool washer
im going to assume its a front loader. try opening the access panel by removing 3 screws along bottom front of unit. give a look inside, there should be 4 suspension/shock absorbers holding drum form shifting.If disconnected the just "snap"into place with quarter turn into holder.while under there the pump is located right there in front, open the "button trap" front of pump see if perhaps theres something inside pump housing making noise
Mar 11, 2008 | Washing Machines
Front Load Washer
have you took the transporting bolt out the back of it yet
Feb 18, 2008 | Whirlpool GHW9100L Front Load Washer
Oil leak
A small amount is not serious. There is no good way of adding oil to the transmission unless you want to take the top off the transmission.
Jan 21, 2007 | Whirlpool LTG5243D Top Load Stacked Washer...
Frigidaire FTF530FS Front Load Washer Logo
196 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
