Question about Magic-Pak 64HWC4-09-301P 2.5 Ton 10.6 SEER Gas Heat Electric Cooling
My heat stop working blowing cool air from vent what should i look for
The thermostat is reading 64 but is set at 85
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Freightliner columbia wont blow heat into cab have replaced thermostats and heater core blend doors work heater core gets hot and blower works but air from vents only gets to 80 deg
The air from the heater core will be as hot as the coolant temperature of the engine. 80 Degrees is the opening temperature of the thermostat and that will be where it remains until the engine starts to work or the ambient temperature rises.
Thermostats come in a couple of different opening temperatures so check around for one that opens around 85 degrees if you want hotter air in the cab
Another point is to close the recirculating vent door to the cabin as the heater core is trying to heat fresh freezing air if it is open
Jan 09, 2015 | Cars & Trucks
Amana Furnace
The furnace may have a cracked heat exchanger.
Dec 19, 2013 | Heating & Cooling
Thermostat keeps jumping back to 85 when i set it to desired cooling temperature
Make sure you are not reading room temp. for starters, the other solution is to reprogram the thermostat in both heating and cooling mode
Jun 12, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Magic-Pak 64HWC4-09-301P 2.5 Ton 10.6 SEER Gas Heat Electric Cooling Logo
Top Magic-Pak Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Magic-Pak Heating and Cooling Expert? Answer questions, earn points and help others
