Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Sd-p5575 wont turn on
After pulling my tv out, unplugging it, taking the back off vaccuming out all the dust from inside, putting it back together (no spare parts left) my tv will no longer turn on. when I plug it in and hit the power button I can hear transitors clicking n stuff but no green light. did I mess something up? and does anyone know the power supply part numbers?
    Genius:
  • 1,153 Answers
Check C258 Video Assy.
Posted on Aug 16, 2007
SOURCE:
How do I take off and clean inside of 32"vizio lcd led tv screen?
I have a Vizio 32 inch HDTV . You will have to place it on a flat surface and take all of the back screws off then pull the ( the back cover) backing of the TV. then is what i did was take it to a low pressure air (for tires) then held it away from the electronics in the back of tv and blew it out . then take it home and put it back together then use a cleaner and a non-abrasive rag for your screen
That got rid of those nasty dust bunnies and i am still using that tv as my monitor . ( I hope that helps you out )
Oct 05, 2014 | Vizio Televison & Video
When I turn the tv on it shuts right back down. I changed the power source and disconnected everything from the tv and it still wont stay on.
I had a Viso do this as well ... I learned that there is a fuse inside. I opened the TV and inspected the fuse ... the fuse checked out ok so I put it back together .... it came on an started working as it should after that! Try unplugging the TV from the wall then push and hold the on button to help drain any power out of the set. While you have it unplugged inspect all of the vent holes to be sure they are clean for proper air flow as over heating and shut down could occur if blocked. If you see dust build up use your vacuum to clean them out. Hook the TV back to power and see what happens.
That's best case senerio .... It could also be that some capacitors have gone bad in the set ... this would also cause this type of behavior. If you are not able to replace something like that on your own it may not be cost effective to fix. Good luck.
Dec 01, 2013 | Vizio L32 32 in. LCD HDTV
Cyclone 3520 by Lasko
first of all unplug while cleaning on .on the sides it should snap together r have clips on it pull apart r lift the snap hindges on hold the blade with 1 hand turn the knob with other clockwise i think wash r take a dust broom to it put back 2 gether
May 15, 2013 | Dryers
Hi I would like to know what kind of spray or solvent to clean the dust inside the TV section, I am in the process of changing the Lamp on a samsung TV .I highly appreciate the help
one way to clean a lcd projector or DLP set when have taken the lamp door off and pull the lamp out use a small brush such as around the house small paint brush or tooth brush and with light see the fan or fans and loosen the dust on fan blades and while doing this if have a small vac or shop vac where the end is small enough to fit inside to vaccum out the dust. If feel safe to take the screws out the back of set and just lightly vaccum out set. Some guys use a can of compressed air that you can get at Radio Shack or possible Lowe's. This is ok just be careful and use vaccum at same time so dust will not go up into the optics/light engine assy in which the lamp is attached to. Really do not need to spray any liquid inside set and always pull power cord before you put hands inside set.
Aug 02, 2011 | Televison & Video
Red light green light on off all time tv will not turn on
ok if you have just replaced the bulb, first try taking out the bulb unit and putting it back in, if you have already tried this, then disconnect everything from the TV unplug it find a nice sturdy place where you can place the tv, at the back of the tv remove the lower back panel ONLY, the screws you need to remove will have an arrow pointing to them, once removed clean all built up dust, remove cooling fan and clean from dust , check it spins ok, remove silver plate in the middle and remove any built up dust, just to the right of the fan there is a sensor unsrew and remove check it is free from dust, on the left of the fan is a micro switch unplug but do not pull on wires to the far right you will see a retainer bar upright (silver) remove this, gentley pull all the circuit board assembly back it will not come out far, on the back circuit board unplug the top two plugs top left but DO NOT pull on wires pull the circuitry board forward just a fraction more, and behind it is yet another multi plug, pull out the one to the left and plug back in but clear any dust in mean time, gently put everything back and plug all that you have unpluged back in gently, put all bars and covers back on, and re-install equip to tv........ this is what i did to mine when i had this probem today after bulb replacement and it now works fine
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
How to clean a toshiba tv screen model # 50a62
snap off the fron cover its pretty tight so kind of pull hard dont worry it wont break its just snaped on tightly, after uncrew 3 screws under the screen lift up and pull out screen there will be 2 wires attached to screen, unplug them to set screen to side. dust off the projectors with dry rag, then clean mirror with windex or any window cleaning product. u are done cleaning front of Toshiba, put everything back together, then unscrew the bottom back and vaccum any dust balls u will see inside T.V. u r now done! let me know how it went.
Jan 29, 2010 | Toshiba 50A62 50" Rear Projection...
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
Emachine T5062 pc wont turn on, I get 5 beeps When the computer performs the ''Power on system test''. I could not remember what BIOS the computer had but I think It was AMI. The five beeps for AMI mean...
make sure it is not getting really hot, also try cleaning all again and start putting them together step by step. make sure the dust didn't got in another part like RAM memories slots, and if you have a big problem with the processor the PC wouldn't even start, wont even turn on.
Nov 15, 2009 | E-Machines eMachines Desktop PC
My phone wont recognize my SanDisk 4gb micro sd
take out your sd card, along with your batterry and sim card, put all but the sd back together turn on, then put the sd card back in, if this does not work, you either have te wrong card or your phone has a fault. or you can go to settings and try to find the card in the list.
Oct 25, 2008 | Lands Phones
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
296 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
