Blinking power light and blue screen
Tried reset with power button on side. not sure what is going on..please help.
  • dustin chenault Jan 19, 2013
    downloaded new software on usb drive and followed mfg's instructions and it worked
    Top Expert:
  • Televison & ... Master
  • 34,255 Answers
Probable power supply failure
Posted on Jan 19, 2013
    if it was a power supply failure then why would it turn on and off and have a blue screen ? it also has a constant green blinking light.
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
ginko
  • 19396 Answers
SOURCE: monitor power light is blinking .but monitor is not displaying anything
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Posted on Mar 06, 2009
SOURCE: blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
Posted on Jun 15, 2009
dsacco86
  • 1077 Answers
SOURCE: Sharp Aquos 32GA5U red blinking light in front but no picture!!!
Right now your TV is in " Protection Mode " because of a failed part inside. The blinking red light is a error trouble code. Only someone with the actual Service Manual for the TV will know what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common board to go bad is the Backlight Inverter Board. It what supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 19, 2009
Afterglow Wireless Headset Blue Flashing mic light
i have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
Jan 23, 2014 | Radio Communications
My wii fit board will not turn on it is new please help
Steps:
  • You need to make sure game is in first
  • push power than blue light will blink
  • after the light finishes blinking and still does not turn on then do sync procedure
  • open the battery side and push the red sync button then quickly push the sync button on the wii and wait for it to blink and light should be on
Mar 05, 2011 | Nintendo Intec Nintendo Wii Fit Action...
Blinking lights? not connecting to tv or blue ray player??
Is the power light blinking??
checked the power adapter and make sure that it is properly plugged in and working fine.
if it is ok, press the reset button on the back of the router for 1min, let go of the reset button and power it down for another min. if lights are still blinking, it may be defective
Sep 14, 2010 | Linksys Wireless-G WRT54G Router
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Lost blue; otherwise normal; blinks 5x
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Display problems please help
This seems to be a problem of the Invertor or powersupply board.If you are technically able check the boards visually,look for bulging discoloured capacitors. Try replacing these components it may solve your problem.
Please provide feedback and rate the solution.
Samir
Jul 25, 2008 | Samsung SyncMaster 731B 17" LCD Monitor
Blank Screen and blinking light
I was using my laptop when it suddenly froze. Tried ctl/alt/del but nothing happened. So I powered down. When I tried to power it back up, the power light comes on, the lock lights blink twice, the fan powers up then down, and the dvd drive clicks on and off. Then nothing--black screen. My laptop battery is nearly dead, so I am always plugged in.
This seems like a common thing with the Inspirons, and here are some of the suggestions I tried:
I removed all power sources, held down power button for 30 sec to reset system and tried to boot up again--same issue
I unplugged the screen closed sensor, thinking the unit might be thinking it was asleep (lid closed), because that what it acts like. No luck.
Removed memory--and reset--nothing.
Replaced button battery on motherboard, now same problem.
Dec 11, 2007 | Computers & Internet
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
