Question about Sony KV-32S42 32" TV
Video on off on off until warm
Runs ok after warm up
    Top Expert:
  • Sony Master
  • 74,136 Answers
Check its main power regulator section circuit for any loose solder terminals. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Posted on Jan 20, 2013
Have a 95 tacoma run normal when cold starts sputtering when warm
Don't know if this will help or not. I had a 1991 Camry that ran fine until it got warm. Would sputter and stall. I cleaned and messed with the throttle body adjustment until it ran OK. Can't remember what I did but there was some sort of adjustment on the throttle body. Good luck.
Jul 08, 2014 | 1995 Toyota Tacoma
Won't start when cold
The cold start valve could need replacing. Also when cold, condensate gets on the wiring causing it to run rough until things warm up. Try covering it up at night. Check your plugs are OK.
Nov 20, 2013 | 2004 Honda Silverwing 600
OK UNTIL WARM THEN BUCKS UNTIL COOL THEN OK TILL WARM
79 chrysler codoba ? don't think its a fuel problem ! I can't believe a cordoba ????????/ really ? I knew someone who had one, white w/ blue interior ! WOW ! after all these years, I need to wrap my head around this . give me a minute ! this bucking violently sounds so familiar ! I'm thinking electrical, BAD COIL, when it overheats, it comes & goes ! spark plug wires need replaced also ! what type of distributor ? replace cap / rotor ! whats in distributor , points ? electronic ? ignition module ? I'm so intune with todays cars, can't remember ! TIMING may also be an issue ! have you checked all the VACUUM HOSES ? EGR valve ? TODAYS FUEL is bad for this vehicle ! need I say more !
Mar 23, 2013 | 1979 Chrysler Cordoba
Engine won't start until gas is poured into carb throat, then runs OK after warming up. Carb was disasembled and cleaned. Didn't run at all before that.
Check the carb settings, make sure you're not running it too lean under a load.
Kohlers always like to run a little on the rich side, especially if tuned with no load.
Warm it up, tune it, then verify the settings with the deck running
(WATCH YOUR TOES - LOCK THE BRAKE DOWN).
Lean (CW) until is cuts out, rich (CCW) until it loads up, 1/2 way between,
then about a 1/4 turn back to the rich side (CCW). And then recheck idle settings.
Feb 16, 2011 | Cub Cadet Garden
Hard starting,may run ok until it gets warmed up,ticking,backfire
either bad head gaskets,oil pump is bad,start with simple things change oil & filter start car listen to see if you have an air leak around intake and or heads hook an oil compression tester up and see if oil is pumping properly if not could be a faulty oil pump
Oct 23, 2009 | 1999 Chevrolet K2500
Cold starts ok warms up shakes and stalls
check engine coolant temperature when it gets warmer, or at operating temperature, and verify that the temperature gauge is showing warmed up to operating temperature. If the coolant temperature sensor tells the computer the engine is cold it will over fuel and miss and the engine will die. When cooled down it will run fine until it warms up. Also could be coil if it starts missing after warmed up.
Aug 18, 2009 | 1990 Ford Bronco II
1989sunbird starts cold then shuts down electricly when warmed up
i would recheck the ignition module, sound bad to me. make sure that you test the module when hot
Apr 20, 2009 | 1989 Pontiac Sunbird
Computer runs too hot then shuts down
remove your fan and install new one ,your hit sneak is not working properly ................ok
Apr 03, 2009 | Acer Aspire One PC Notebook
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
