Question about Casio G Shock DW9052 1V Illuminator watch
How to set an alarm on a g shock 3232 - Casio G Shock DW9052 1V Illuminator watch
  • Casio Master
  • 18,392 Answers
Click here > http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3232.pdf for instructions ........
Posted on Jan 19, 2013
Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
Mar 10, 2011 | Casio Watches
CASIO G-SHOCK 200 (G-7500)
The first thing I have to recommend it to unscrew it and remove the battery for a few minutes and then insert it back.
If this has solved your problem please rate this solution as "Solved" otherwise please ask us here again for more possible solutions.
Thank you :)
Oct 12, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 | Watches
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
Press C until timekeeping mode is reached (high beep).
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Alarms, alarms, alarms
Press mode until in Alarm Mode
Press Receive until alarm # shows AL1-4 or Sig
Press Time/Memo to change alarm on or off. On is shown by indicator next to alarm name.
Mar 04, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Timex 1440 Sports Aggressor: how to set time and alarm
i just bougth a 30 lap shock/resistant timex ironman triathlon, and i need to know how to use it... i have no instructions thanks
Jan 23, 2008 | Timex 1440 Sports Aggressor 56014 Wrist...
Casio G Shock  DW9052 1V Illuminator  watch Logo
778 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
