Question about Ricoh Aficio 2022 All-In-One Laser Printer
The code 792 is blinking
How come it blinks , but everything works ok
Sc 230
Posted on Jan 19, 2013
  • katomp1951 Jan 21, 2013
    No did not help
How do I fix black screen? Red light blinks 8 blinks then stops about 3-4 seconds then 8 again.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 25, 2015 | Televison & Video
Sony kv ha21m80 4times blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 10, 2014 | Televison & Video
Toyota Echo 2003 SRS light with ABS light blinking instead of Seat Belt Light
When you sit in the seat and put the seat belt on does everything work ok . If so look to the fact that you are required to wear a seat belt and the fact that you are not might be the problem.
Mar 09, 2014 | Cars & Trucks
Driver side turn signals will not blink.I have replaced bulbs The flasher works
When you turn on your hazard lights, does everything blink OK? If so, that confirms that the flasher unit is working properly, and that the bulbs are OK.
If the light does not even illuminate when you use the turn signal, and the step above showed everything working, then the problem is the turn signal combination switch beneath the steering wheel is defective.
Apr 16, 2011 | 1994 Isuzu Trooper
Hey I'm trying to program my Comcast remote to control a Vizio VHT510 sound bar sound system bought at Costco. Any ideas if there is a way do do this?
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Dec 14, 2010 | Vizio VX37L Television
Looking for remote codes for vizio sound bar and comcast remote
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Aug 28, 2010 | Vizio High Definition Sound Bar
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
Dec 07, 2009 | Televison & Video
LG L1940HR screen blinks for 1 min. when turning monitor on
some monitors blinks when you have a start up. this usually happens on an outdated video cards. so if it works fine then its ok then. but try checking if you have the latest update for your video card. this happens on an outdated nvidia geforce 7300 go on a laptop runing on windows vista 32 bit. once i updated the videocard, it doesnt blink anymore at start ups.
Feb 06, 2009 | LG FLATRON L1970HR LCD Monitor
My 1998 Dodge Caravan has a service engine soon light on.
Well barwest , you should always have code 12 ,,, 1 blink then 2 blinks , this is not a prob it is a code to tell you that the onboard dyignostics is working. now for the code 55 this means that the code read is done . so the numbers in the middle is really your prob but you are missing a number with the 3 , do the key again and let me know remember your code is after the 1 blink and 2 blinks ,try that ,there is a number missing ok , joe
Sep 27, 2008 | 1998 Dodge Caravan
Ricoh Aficio 2022 All-In-One Laser Printer Logo
143 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
