Question about Velocity Micro Edge Gaming Desktop PC Silver (Mx140)
Power on, One long beep, no keyboard/mouse or video
  • Velocity Master
  • 13,433 Answers
Hi there
if you are sure that you are only getting a single long beep then that would indicate a problem with either, the powersupply or the mainboard.
it is really difficult to advice you on what to do at this point because the error is only a long beep, you would have to bring the computer to me so I could take a closer look at it.
So I would recommend you take the machine to a local repairer for a diagnosis.
Posted on Jan 19, 2013
My desktop sounds like its on but the monitor, keyboard & mouse don't seem to also when I press the power on button after a little while it beeps about 4 times.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Feb 02, 2013 | Dell Alienware Area-51 Gaming Desktop...
Gateway DX-4831
sounds to be a bad motherboard
Jun 24, 2017 | Computers & Internet
Continuous beep
> continuous beep
Either:
* failed CPU fan (your computer is about to overheat)
* failed RAM
* failed video-card
* RAM that is not properly "seated" in its slot
* video-card that is not properly "seated" in its slot
* keyboard plugged-in to MOUSE port
* mouse plugged-in to KEYBOARD port
* dying power-supply
Check them all!
Jul 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Apr 01, 2011 | Dell Inspiron 530 Desktop Computer
When i turn my dell on it jus beeps my mouse, keyboard & screen are off. also a,b ,c,d lights on
Did some checking. The mouse,keyboard and screen get there power the motherboard and the a:drive b:drive c:drive d:drive get there power from the power supply. The mother board gets it power from the power supply. So the problem is in the mother board. You can try to remove the battery for a minute and put it back with it unplugged of course to reset the Bios or jump the Bios pins on the board same thing.Check to make sure nothing is loose inside.Sometimes video and ram that get loose will make a computer beep and shut down and a bad stick of ram will to.
http://www.chuckstar.com/blog/technology/gadgematch-3-buy-a-new-pc-vs-build-your-own-system/.
Feb 12, 2011 | Dell Dimension 4700 PC Desktop
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
My mouse works, but whenever I hit any key on the keyboard, the computer just beeps.
Check that the PS/2 keyboard is *NOT* plugged-in to the PS/2 "mouse" port on your computer.
Or, borrow a keyboard, and see if that keyboard is "beep-free".
Nov 27, 2009 | Logitech S520 Mouse
On first power up, no video, no sound.
hi
*********** board dead
hope ur smps &ram also ok ......
pl z check motherboard near pc service care.......
Jan 12, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Velocity Micro Edge Gaming Desktop PC  Silver (Mx140) Logo
44 people viewed this question
Top Velocity Computers & Internet Experts
Andrew Taylor
Andrew Taylor
Jovan Sakovic
Jovan Sakovic
Anthony Cardenas
Anthony Cardenas
Are you a Velocity Computer and Internet Expert? Answer questions, earn points and help others
