Question about Seiko Coutura Chronograph Watch
Seiko runs for a day after battery replacement
My Seiko Kinetic winds down in one week after weaking a years and is not recharging to run after one day of wearing.
It sounds like that it is time to replace the capacitor with a new Lithium Ion battery. Send it to Timelywatchrepair.com. Go to this web sight
Dec 29, 2009 | Seiko Kinetic watch
Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
Dec 11, 2009 | Seiko Divers SKXA35 Wrist Watch
My Seiko Pulsar Dress PJ6010 was running fine until it seemed like the battery was going out. I had it replaced and a few days later it stopped again. Could it be the battery gain? I have had other PJ6010...
D you mean battery drain, not gain? Possible other causes are: Maybe you got an old battery put in, this does happen sometimes. Or, maybe the lubricants have dried out causing the gears to get sticky/gummy and causing excessive battery drain. I use an instrument than spin the movement and loosen up sticky gears after using a spray cleaner.
Dec 06, 2009 | Seiko Pulsar Dress PJ6010 Watch for Men
Seiko Chronograph Sport 150 - Problem: After Battery replacement and pressure test (15-Bar), watch hands are not in the correct place. Can this be fixed so the chronograph timing features, and month &...
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Nov 20, 2009 | Seiko SNA553 Alarm Chronograph
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
15 to 20 minutes fast per day
if your caliber is automatic 7s26b something is wrong with the hair spring try a seiko service center anyway isnt something that you can fix by yourself!beware!far away from jewelers and local battery changers and other monkey magicians!automatic watch calibers are delicate and they ruine them!
Jan 21, 2009 | Seiko SKX173 Wrist Watch
Seiko watch mechanism replacement
nice day to you! your watch is need of general cleaning and recondition ,efter cleaned and condition the machin ! be sure that the case back gasket is good and apply a small amount of silicon greas to avoid water damage ! close it verry tight ! good luck !god bless !
Sep 02, 2008 | Seiko Watches
My seiko kinetic watch stops working overnight but it is fine whilst wearing it
Further to the previous solution...
Despite Seiko's claims regarding never having to change the 'battery', the power storage unit or ECU in Seiko-speak (not technically a 'battery') does eventually need replacing. From the symptoms you describe, it sounds as if the 'battery' on this watch is on its last legs as it is no longer charging properly. The good news is that it doesn't have to be an expensive job to have it replaced (providing you avoid going through the local jeweller <==> Seiko chain!). There are companies on the Internet who offer a replacement 'battery' service. I've used one in the past and was very satisfied with both the cost and the good service. A Google Search will probably return a choice of several in your country. Btw, if you have had your Seiko Kinetic for a few years, its probably worth paying a bit more and having it overhauled (clean and oil the movement and replace the watertight seals) at the same time.
Jul 30, 2008 | Watches
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
My Kinetic watch stopped working.
I highly suspect and probably you also suspect that the energy storage capacitor needs to be replaced. My experience in working on these is that they are only good for about 3-4 years. I only replace with a new Seiko Lithum Ion battery. Check www.timelywatchrepair.com
Aug 02, 2006 | Seiko SKA192 Wrist Watch
Seiko Coutura Chronograph Watch Logo
23 people viewed this question
Top Seiko Watches Experts
Lawrence Oravetz
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
