Question about Kenmore Dryers
Kenmore Dryer Model 970-C82062-10
Dryer squeaks.Doesn't sound bearing related sounds like metal on metal
  • 979 Answers
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Posted on Jan 25, 2009
My FEX831FS4 squeaks horribly when dryer is rotating. what has worn out to have the drum rub ,and can it be fixed or replaced?
this is a frigidaire dryer usually when they make a sound like metal on metal it's the rear bearing on the back of the drum,if you look in the drum you'll see the three phillips screw in the middle that holds the bearing on part 5303281153 go here to see it
https://www.repairclinic.com/PartDetail/Drum-Bearing/5303281153/1851
Dec 27, 2017 | Dryers
Magic chef dryer making very loud noise as it turns, how to get the bottom off
No need to take the bottom off - the top, front, and back come off - if the noise is a rather high pitched squeak the pads on the drum are worn out, if it sounds like a squeak but more metallic/raspy sound check the motor bearings, also check the drive belt.
Oct 13, 2014 | Dryers
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Aug 14, 2014 | Kenmore 84052 Dryer
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
KENMORE DRYER SQUEAKS ON DRYING CYCLE. WOULD LIKE TO FIND THE PART # SO I CAN ORDER A NEW BEARING. MODEL 970-C98802-10, IT 12 YRS OLD. STACKING SET. THANKS
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 17, 2011 | Kenmore Dryers
Our clothes dryer squeaks when it is drying clothes. How can it be fixed or what is the problem?
Most time them squeak is like bad brake pads on a car. The plastic bearing is gone and now the drum is riding on the metal bracket. The front of the drum rides on slides and when they wear out you get a scrubbing sound and not so much a squeak. So i would say you have a GE/Hotpoint type dryer with a rear bearing that looks like this:
WE3X75
My Dryer problems and solutions blog page
How it works: GE clothes dryer
Mar 31, 2011 | Dryers
My Maytag dryer MDE9606AZW has started to squeak, sounds like a fast spinning squeak, sometimes loud and sometimes quieter. What might be causing this and how do I fix it?
It's likely your drum ring bearing has worn out. It's a strip of plastic that keeps the metal parts from rubbing has the barrel turns.
Mar 05, 2011 | Maytag MDE8000 Dryer
Dryers Logo
1,090 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
