Question about shop-fun Q88 7 inch Android 4.0 Boxchip A13 1.0GHz Tablet PC
A13 chip overheating
When charging, screen gets very hot and tablet will not power on
Tablet will not turn on even fully charged and I just bought it for christmas
I had something similar happen with mine, and after searching online for the solution, I discovered that holding down the power button while pressing down on the volume bar at the same time somehow trips everything back into operational mode. It may not work the first time, it didn't with mine, but just keep pressing both at the same time and sooner or later you will have a screen appear and be able to use your tablet once again. Hold both down and press repeatedly.
Jan 11, 2016 | Tagital Tm 9" Android 4.0 Tablet PC...
I can't figure out how to charge the battery. I rec'd a AC wall charger but I can't figure out where to plug the male end in on the tablet
The charger plug should plug into the mini-USB port. This is the same port for the USB cable that would connect to the computer, and in fact the tablet can be charged from the computer if the computer is on.
Mar 23, 2015 | Tagital Tm 9" Android 4.0 Tablet PC...
How to get my cromo inc tablet to power on after i factory reset it
Odd, but try this: Some tablets do not fully shut down, even though the screen goes blank. Hold down the power button for 30 seconds, wait 15 seconds, and then try again to power up (hold power button for 3-5 seconds). Wait patiently for the power up, as power after factory reset may take longer than a 'typical' start-up. Good luck!
Jul 18, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
My tagital tablet stuck on android screen
Hold down the power button for 30 seconds and then turn it back on.
May 01, 2014 | Tagital TM 7" Android 4.0 4GB MID...
Android A13-MID tablet can't connect to WiFi
I can't get the tablet to reboot it stays on android screen
Dec 25, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Battery issues
Sounds like you have far too many apps installed all demanding cpu and network (wifi) work even if they aren't open . Have a purge and be ruthless! Get rid of every app you don't use. Try and stay in same room or near to router so it's wifi doesn't have to use high power to stay in contact with it. Reduce the screen brightness as much as you can. looks dull at first but you soon adjust and get used to it. Remember the usb keyboard is also getting it's power from the tablet battery and will use much more than the touch screen does.
In my experience the batteries on these are quite small. There is enough space inside for a battery 3 times the capacity of the one fitted. You might want to consider getting the battery replaced with a higher capacity one,. There's videos on youtube how to do it, or you could ask a local computer repair shop for a price.
May 29, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
Forgotten password on my Q8 A13 MID tablet
I added a password on my q88 Android A13 tablet with one letter and numbers but when I tried to get in, it would not let me get into my tablet. What should i do
Apr 06, 2013 | shop-fun Q8 of A13 7 inch Android 4 flat...
shop-fun Q88 7 inch Android 4.0 Boxchip A13 1.0GHz Tablet PC Logo
70 people viewed this question
Top shop-fun Tablets & eReaders Experts
Are you a shop-fun Tablet and eReader Expert? Answer questions, earn points and help others
