Question about Sony STR-DE915
Rear speakers not working - Sony STR-DE915
"2000 Buick Park Ave. rear speakers on deck lid stopped working nine speaker system all others work
First, check the fader on the stereo, then, check the wiring from the stereo to the amp and from the amp to the rear speakers. The amp controls all speakers, not just the rear so it seems that it is still working therefore the fuses must be good. If you have access to any other speakers, I would try plugging one in in place of one of the rear speakers and seeing if it works then you'll know if it's just the speaker or not.
Jul 25, 2015 | Buick Cars & Trucks
Peugeot instructions how do I switch on rear speakers they have never worked. Easy answer perhaps just hven't switched them on. How do I do that.
It should have a balance nob on the face of radio front and rear,make sure wires are plugged on to speakers.
Jul 30, 2014 | Audio Players & Recorders
98 Durango Rear Speakers not working
look under back seat for preamp
Jun 01, 2012 | Cars & Trucks
Radio harness diagram for 95 chevy tahoe....rear
check wiring on passengers side near the rear hatch speaker, the rear door speakers are run through them also. i had the same problem and it was a unplugged connector at that location
Sep 17, 2009 | 1995 Chevrolet Tahoe
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
Need diagram for wiring radio for 1997 Hyundai Sonata
1997 Hyundai Sonata Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Red
Car Radio Switched 12V+ Wire: White/Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Door
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/Whi
Mar 20, 2009 | 1997 Hyundai Sonata
Speaker Detect error Left Rear
Hey there.
I had the same problem until i figured out that if u dont have surround speakers connected it will be a error when trying to configure the rear surround speakers.
So if u are running a 5.1 system and have hooked up ur surround speakers to the back surround speaker port u have to change them to the surround speaker port.
Hope this work for u
Jan 11, 2009 | Audio Players & Recorders
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Rear speaker not working
If you did the 5.1 sound test and the rear speaker works, sometimes you have to see in your software speakers settings,probably you need to change to 5.1 speakers
May 28, 2007 | Dell WL6000 Computer Speakers
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
