Question about Canon PIXMA MP150 All-In-One InkJet Printer
Ink absorber full
How do i fix or change
  • Canon Master
  • 32,281 Answers
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Posted on Jan 19, 2013
SOURCE: Waste ink absorber
This is actually a very easy fix. Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.How to clear E27 Code
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
  • Turn off the printer.( it must be turn off) then turn it on again.
Posted on Jan 23, 2008
pattersj78
  • 70 Answers
SOURCE: How to fix "Ink Absorber Full"??
The ink absorber is a small piece of material that is used to hold the ink that is scraped from print heads on the ink tanks during cleaning.  I suggest, wearing gloves of course, removing the material, which resembles a sponge, and cleaning it with warm water.  Allow sufficient time to dry, clean the sensor with a cotton swab, and reinstall.  Remember to change the ink tanks at the same time, in order to reset the ink counter.  There are new absorbers available for purchase on the web, if you don't want to clean the old one.  Others have had similar problems, Canon suggests sending the equipment to them for repair.
Posted on Oct 19, 2007
SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
Posted on Apr 30, 2008
sams_trix
  • 93 Answers
SOURCE: The waste ink absorber is almost full. what do I do?
Printer are blind, they just depend the on commands,every time you clean the head, printer will register that there is an ink sucked from the head,to reset the invisible ink, unplug the printer, press and hold power button, press feed button 3 times with 1 sec. interval (notice the light will change color every time you press feed button)release both buttons and press power.If the ink is visible, syringe can help, remove ink hose and **** the visible ink.
Posted on Aug 27, 2009
Testimonial: "I am going to check with my nephew to see if with this info he can solve my problem. Thanks"
pineworks
  • 4041 Answers
SOURCE: I HAVE AN IP2600 WITH INK ABSORBER ALMOST FULL.
Hi there with most canon priters you can reset the waste ink but I myself have not seen one for yours.
I have put a website fr you to look at click on the link it will take you there.
http://www.tradebit.com/filedetail.php/4595501-canon-ip1200-ip1300-ip1600-ip1700-ip1800-ip2200
All the Best Pineworks
Posted on Feb 11, 2010
How do i fix ink absorber is full
the ink absorber needs to be changed and the counter reset. The absorber may not be full however as these counters are based on pages printed in most cases.
Jan 27, 2015 | Office Equipment & Supplies
It is saying that the ink absorber is almost full how can we change this
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. There are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk. I will not advise you as it is not a permanent solution.
Sep 21, 2011 | Canon PIXMA MX850 Multifunction Printer
How to fix a full ink absorber
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Aug 22, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink absorber full. how to fix?
There are ink absorbers located at both ends of the printerwhere the ink head move.
Then take several sheets of absorbent tissue, fold it into a pad and place it insidethe printer over the ink absorber on the far left hand side of the printer tosoak up the excess ink. You may need to change the absorbent tissue a fewtimes. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jun 10, 2011 | Canon PIXMA iP1600 Printer
"ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
Mar 31, 2011 | Computers & Internet
Absorber is full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Ink absorbers almost full in Canon Pixma iP 1500 how can I fix it yourself
Hi ...
Please vote if this helps ... Cheers :)
Jun 26, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma ip2000 saying waste ink absorber almost full
This is quoted from cannons website about your issue.
"This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
Here's the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10237&kbpage=yes
So what they are saying more or less is throw out the printer because it's going to cost more to replace the absorber than to just buy a new printer.
If you ak me it's just another way these printer companies screw customers. Just my opinion.
Sorry about the bad news but at least you have your answer.
Sean
Mar 12, 2009 | Canon PIXMA iP2000 InkJet Printer
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Oct 19, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
329 people viewed this question
old marine
old marine
