Question about Dishwashers
I have an ASKO 1605 Diswasher I am trying to replace the top front panel on the door I cant remove the control dial on the front how does it come off
Model 1605
  • Malcolm Annis Jan 22, 2013
    The front dial needs to be removed from the panel so I can remove the control unit from the back of the panel but I can see no method of releasing it should I pull it very hard?? or what??
3 Suggested Answers
  • 246 Answers
SOURCE: Are white front door dishwasher replacement panels available?
Absolutly! There is a website that allows you to do a bunch of stuff to the front of your dishwasher , including changing colors, without actually unscrewing anything. Check out www.applianceart.com. They do sell stainless metal panels for cheap there too.
Posted on Nov 12, 2009
Macmarkus
  • 2605 Answers
SOURCE: need replacement control selector pad
Hello, Welcome to FixYa.
The part you`re looking for on the Asko 1805, as I understand your description ( please correct me if I misunderstood )...
the overlay/decor insert across the top of the control panel is Asko part # 80-708-88 (then a -0 for white or -33 for black depending on the color the last digit?digits change).
Check "repairclinic.com" part number 764259, retail for approx. $80.
Hope that answer`s your question. Let me know if I can assist you further.
Thank you for choosing FixYa today.
Please take a moment to rate the information I provided for you and a testimony if you fell it`s warranted.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 04, 2010
Testimonial: "Very helpful in identifying parts for replacemnt with part numbers. Quick response."
How do i remove the front panel of the asko t721 to replace a broken belt?
REMOVING THE FRONT PANEL
1. Remove the top cover.
2. Remove the lower cover.
3. Remove the door.
4. Remove the front drum frame.
5. Remove the four screws that secure the front panel to the side panels.
6. Remove the two screw that secure the bottom edge of the front panel.
7. Lift off the front panel.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the
top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE LOWER COVER
1. Remove the two 20 torx screws (A) at the
bottom of the lower cover.
2. Next, grasp the sides and pull it forward and
down.
25764946-gtkp3url2ghtdqenstp5bokb-1-2.jpg REMOVING THE FRONT DRUM FRAME
1. Remove the motor (see page 34).
2. T700/760: Remove the exhaust vent by
twisting it free.
3. Remove the wire bundle from the cable clamps
on the front drum frame.
4. Remove the fan housing cover (see page 33).
5. Using flat-nose pliers, take out the thermistor.
6. Open the front door.
7. Unscrew the four screws that secure the drum
frame to the front panel.
8. Lift out the drum frame.
REMOVING THE DOOR
Note : The front door must remain closed during the entire removal procedure (The door magnet will hold it
in place.)
1. Remove the lower cover (see page 24).
2. Unscrew and remove the three screws that secure
the hinge fixture.
3. Lift down the front door.
Dado
Jun 29, 2015 | Asko Dryers
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
Replacing wax motor
Not very difficult actually. Strip of the screws around the inside of front door, and the two on top of the panel. Twist of the fan cover, and then the wax is attached with a Torx 10.
Sep 02, 2013 | Asko Dishwashers
On the front panel there is a wire unplugged, there is a spot for it, just wondering if that could be why it blows the circuit breaker when in heat cycle. Asko 1605 dishwasher
HI,
No is the answer to your question. The heater circuit does not run through the door panel, thats only a safety ground so you don't get shocked if something goes wrong. I would look into the heater circuit to solve this problem. Asko directly can help you and possible walk you through this problem. Some of the problems were know to be in the control board, others were in the heater itself. 1-800-966-2756 is Asko's direct number. I am a servicer and this is the number I use. I would like to direct you in the correct direction but there are a couple of things that would be needed to fix this problem and without seeing the unit it becomes a cat and mouse game.
Can them for the correct answers, If you have problems there, I would be glad to help the best I can with manuals or parts needed.
Good Luck
Aug 19, 2011 | Dishwashers
Asko washer door won't close. Worked it manually fine with screw driver flicking latch switch but door wont connect with latch. How do you get behind switch panel to replace switch or see whats going on??...
you would start at the top back by losening the screws that hold the upper cover on the machine and when you remove these screws you would then slide the panel to the rear of the machine. nest you will see the rubber gaskey along the door has a metal ring simply use a screw driver without ripping the rubber boot to remove the ring. After this then u can remove the screws which hold the front panel which also has the door on it the part you are describing sounds like the door hasp or the catch the holds the door closed. because it is an asko your probably better off going to manufacturer to order your parts because this is a foreign model. please remember to rank how this opinion has helped in your appliance situation and if i can answer anything further please message me back
Thanks again
Rick
Nov 28, 2010 | Asko W6021 Front Load Washer
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
Machine not starting , door not closing well, no click from locking mechanism
The door latch and or door handle assembly which also holds the door switch may have brocken.
If the door latch does not shut properly, this will not close your door micro switch. And if the switch is not closed then the machine will not operate.
Turn off machine at the power source. Open the dishwasher door. You may want to put some weight on the door to stop it from springing back up.
If you have a star allen key or a star shaped tool, you can open the screws around the stainless steel plate of the dishwasher door. Start with the ones on top, which secure the control panel and door lock. See if you can remove the control panel gently without having to open the screws for the front door panel. Sometimes you may need to loosen the front panel screws to free the top control panel.
Once you remove the panel, you will notice a door handle assembly which also holds the micor switch. Take note of how it is set up. Also examie to see if any plastic parts are broken. You may need to order the complete door latch or door handle assembly and replace.
While doing this make sure the machine is turned off at the power source.
Good luck.
Ash
Nov 17, 2009 | Asko 24 in. D3121XL Free-standing...
Door seal leaks cant how to remove and reinstall
1: remove the top panel
2: remove the lower front panel
3; remove the control panel
4: remove the screws holding the door switch
5: remove clamparound the door seal and remove front panel (2 screws bottom and 2 up)
6: remove clip around door seal that holds tothe tub
7: replace seal....
there you go!!!
Jul 04, 2009 | Whirlpool Washing Machines
Whirlpool adg 7560
on must hirlpool the top console has control on front upper side,,if so you must remove console and bottom panel,,because your panel will be thicker you must get 1 inch counter screws remove diswasher orginal panel than add you bottom,,,,if it dishwasher that has control bottons on top side of doorplace panel over hold door the remove 4 inner panel screws and replace with 1 and a half in screws ,and mount straight through
Mar 22, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Dishwashers Logo
Top Dishwashers Experts
