Question about Canon PIXMA MP150 All-In-One InkJet Printer
How do you change ink absorber
Says it needs replaced
    Problem Solver:
  • 8 Answers
Replacing the absorber is a hard task. if this is the first time you have had this problem.
Hold the ON/OFF button down, while holding the Stop/Reset botton down. Look under your finger untill the green LED is on. Then follow these - press reset button twice, wait a few seconds, and then press it 4 times. (You hold the power button down the whole time.) Then let go of both buttons. Then turn off the printer, it takes a while to respond to this. Turn it back on and off you go!!
Posted on Jan 20, 2013
hemantraj
  • 638 Answers
SOURCE: Canon Pixmaip2000 printer
get your printer serviced so that the technician can clean of the absorber and place it back.the absorber cost is very minor, it is normally covered in the technicians service charges.
Posted on Jun 04, 2008
patemi
  • 366 Answers
SOURCE: where to get replacement waste ink absorber for canon pixma iP300
Following this page I got some positive results
Posted on Feb 05, 2009
websnail
  • 419 Answers
SOURCE: When I try to print, I can't; it says "The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber."
This error means that the waste ink pads have filled up to the point where the printer believes the ink will overflow and leak or cause damage to the printer.
To give you a quick primer... Every time you run a cleaning routine or printer borderless photos the printer will dump a small amount of ink into a set of highly absorbent pads that live in the base of the printer.
These pads can only accept so much ink before they become full but experience has shown that you could reset the EEPROM waste counter if you locate the appropriate codes for your printer.
I'd recommend asking on nifty-stuff.com in the forums and see if someone can provide the information and code you need.
Hope that helps.
Posted on May 21, 2009
cene765
  • 787 Answers
SOURCE: Ink Absorber full,needs changing.How do I Change
You need to disassembling the hole printer to find and replace the ink absorber.It's on the bottom from right side under the pump station.
Also you need to reset the ink counter:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Nov 03, 2009
  • 1739 Answers
SOURCE: Ink absorber is full and must be changed. Waste
You might want to try just resetting your printer rather than changing the ink pad. The warning is based on a count of how much printing is done, not a measure of full the ink pad has become. Consequences of not changing the ink pad, if truly filled to capacity, could be ink leaking from the bottom of the printer.
The following video show how to perform a reset that should work for your printer. The second video will give you an appreciation for how to change an ink pad and help you to decise whether you wish to attempt.
Trust this is helpful.
Posted on Dec 18, 2010
Where can I get a Parts List for a Canon MX850 MF Unit
Ink Absorber Full
This may clear the ink absorber problem.
There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Apr 23, 2013 | Canon PIXMA MX850 Multifunction Printer
Mp510 waste ink needs emptying
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
Jan 22, 2013 | Canon PIXMA MP510 All-In-One InkJet...
Ink absorber full
Ink Absorber Full
Jan 19, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
Aug 19, 2012 | Office Equipment & Supplies
Canon ip3500 series the ink absorber is full contact the service center
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Aug 07, 2011 | Canon PIXMA iP3500 Printer
My pixma ip1980 ink absorber is full. how to change or clean manually?
You can't. Here is what Canon says on their website:
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
If you feel your product might require service, Canon has excellent service options and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
Jan 07, 2011 | Office Equipment & Supplies
Waste ink holder is almost full. Where is it and what does one do with it?
Hope this answers your question.
Jan 07, 2011 | Canon S900 InkJet Printer
Ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
Nov 05, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Power lamp always red. The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber.
You need to have the absorber replaced at a shop where they can reset the count after changing the absorbers, otherwise ink could overflow and make a mess.
Jul 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My cannon iP 2000 keeps that waste ink well is full how do I repair this
No repair is available. There is a little tray under where the cartridges rest and when the printer does a cleaning cycle, it squirts some ink into it. Eventually, the ink builds up and when the tray is full, it's time to change printers. Here is what Canon says:
Try this link on how to reset the ink counter: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelFeaturesTabAct&fcategoryid=257&modelid=10237#SupportDetailAct
Oct 20, 2008 | Cannon Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
