Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Video blinks on off until warm
Blinkinking stops after several minutes warm up
    Top Expert:
  • Sony Master
  • 74,482 Answers
IIC bus signal is being blocked is the fault. Check the main baord's main system control section circuit. The work is a very skilled one.
If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Posted on Jan 20, 2013
I have a 24" snowblower that surges after 1 minute of running, after 3-4 minutes stops and will not restart until several hours later, does the same thing over and over
This sounds like a choke issue. Do you have a choke on that engine?
The purpose of a choke is to allow for a varying air:fuel ratio depending on how hot the engine is. A cool engine needs a more rich mixture of fuel to air. Once the engine warms up, it runs best with more air. The Choke is a mechanism that allows the operator to manually adjust this mixture. Generally, the choke is closed to start a cold engine, then is opened in 2 or 3 stages as the engine warms up. As the operator, as the engine starts to run smoothly, you would actuate the choke to the next notch, changing the fuel:air ratio so more air is mixed in with the fuel. It's probably best to give the engine a few minutes to warm up while you progress through the choke stages until it's fully open providing the best mixture for operation prior to beginning to clear the snow.
If you follow that process and the engine stalls when the choke is opened, then you need to clean your carburetor.
Oct 18, 2012 | Garden
Epson R230 2 red light start
epson R230 2 red light start
Printer status Fatal ERROR
LED indicator
power: OFFpaper: FAST BlinkInk: FAST Blink
Carriage Unit cannot move correctlyMotor cannot rotate correctly
Note: CDR (CD/DVD) guide assembly is not close properly will also occurs error or blinking the paper indicator and ink indicator.
For easy to me to understand.Please check the light indicator, either blinking simultaneously?
Jun 20, 2012 | Epson STYLUS R230 InkJet Photo Printer
Tv blinks until it warms up
Gateway does not offer much in the way of parts or service information--I would suspect the power supply which could of course be checked to see if voltages remain stable or change after warmup.
Other than that the main board is next in line.
Jun 11, 2012 | Gateway PLSM50TV 50 in. Plasma Television
Message symbol blinks on Nokia 3110c!
i think thats what they are designd to do so you dont miss any important messages
my nokia 6300 does the same thing
hope it helps
Nov 27, 2011 | Nokia 3110 Cellular Phone
In insight display led the second led of power supply blinking and this blinkinking accrued in irregular time
It might blinks due to old firmware....Please update firmware & let me know if this works...
Mar 04, 2011 | HP ProLiant DL380 G5 (408790-001) Server
How to set time of day clock on 2007 1200n
Turn the key to ACC,
press the button on back of speedo several times until time is displayed,
press and hold for 5 sec, 12HR begins to blink,
press and release to switch between time formats,
press and hold for 5 sec, hours will blink,
press and release repeatedly to set hrs,
press and hold for 5 sec to get blinking minutes,
set minutes similar way,
press and hold for 5 sec to save, when minutes stop blinking the time is set,
turn the key to off.
Jul 27, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
2002 Big Bear 400. Dies after a few seconds upon startup
sounds to me the valves are not properly adjusted,..like their to tight,...i had run into this in a japanese car once,...check it out and let me know,.....cracklin joe
Jan 10, 2010 | 2002 Yamaha SR 400
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
How to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
13 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
