Question about Air Tools & Compressors
What type of oil do I use in an able cooke colt 255 air compressor
Able cooke 255 colt air compressor
  • 323 Answers
SOURCE: Oil type for air compressor
You can go to any Home Depot and buy compressor oil for your compressor. Your operators manual should tell you what the level should be, however if you don't have one, filling it with oil until it fills the glass tube about half way should be sufficient.
Posted on May 22, 2009
  • 1388 Answers
SOURCE: Air Compressor
Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
Posted on Apr 01, 2009
lester482529
  • 226 Answers
SOURCE: What type of oil can you run in an air compressor
any compressor oil is fine.go to your local hardware store.doesn't have to be name brand.hope this help's
Posted on Jul 11, 2009
ollie reece
  • 1167 Answers
SOURCE: type of oil
here is a bottle for £10 a litre we can supply it for you buddy but just saves hassle buy from ebay instead http://cgi.ebay.co.uk/COMPRESSOR-OIL-1Lt-SUITABLE-FOR-DIRECT-OR-BELT-DRIVE_W0QQitemZ120471848230QQcmdZViewItemQQptZUK_Air_Tools_and_Compressors?hash=item1c0cae8526&_trksid=p3286.c0.m14
Posted on Sep 27, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Where do I buy spare parts from for the Able Cooke Colt 255 air compressor?
    I broke the air flow adjuster knob where do i find it
    Jan 31, 2013 | Vacuums
    I was airing my tires day before yesterday,I noticed the com was running for a long time.When I went to turn it off it was really warm. I have never noticed it getting that warm before. ( I have had it for...
    all air compressors will build up heat especially if they run non stop it is normal for them to get warm .an air compressor will cook itself if it doesnt cycle off and on and made to run continuously for long lengths of time which really depends on the type most home owner type air compressors are junk especially oil free oil less the best air compressors are cast iron oil lubricated which there is also aluminum oil lubricated which when thoes fail you just throw them away .cast iron pumps are better made and are rebuild able.oil free are noisy not very dependable.
    Jun 14, 2011 | Campbell Hausfeld Air Tools & Compressors
    We have Ingersoll Rand Type 30 Reciprocating Air at about 20years old.. what type of oil is used in the crankcase?
    Almost all compressors use sae 30, you can buy it labeled compressor oil. The key is compressors use a non detergent oil.
    Mar 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
    Hi ...I have Sperre Reciprocating Air compressor...i have problem that crank case oil turns milky in color ...its sure tht this is sign of condensation or water contamination in oil but...
    That is moisture in the pump oil. Not good. You need to drain it and replace it or cook it on your stove to boil out the moisture. Cooking the oil is dangerous and the heat must be just enough to make the water boil up and out but not take the the oil into a flammable temperature range or overheat the oil. Not going to smell good cooking either.
    Jan 28, 2011 | Air Tools & Compressors
    Able cooke air compressor colt 255 instruction manual
    Have a Colt 255 that won't build air pressure. Any hints?
    Oct 14, 2010 | Vacuums
    What type of oil does this unit take?
    Air compressor oil. I prefer synthetic, but you can use regular compressor oil also.
    Jun 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
    May 10, 2010 | Ingersoll Rand - Rand Type - 30...
    I CANT HAVE THE FACTORY OIL TYPE IN MY COUNTRY, CAN I USE ANOTHER TYPE? AND WHAT IS THE TECHNICAL NAME ? MY COMPRESSOR IS GA30 ATLAS COPCO TYPE.
    Most air compressors will run fine using 30 weight non detergent oil.
    You could drop the manufacturer a e-mail.
    Your compressor shouldnt use a lot of oil ... maybe you are in need of some repair? New rings or bearings or seals?
    Feb 23, 2010 | Air Tools & Compressors
    What type of oil for Mitsubishi Colt gear box
    First drain completely out whatever is in it. All the gear boxes and rear ends use 90w gear oil. Buy a name brand.Some of the really cheap stuff is recycled used oil.
    I hope this helps you.
    Sep 11, 2009 | Mitsubishi Colt Cars & Trucks
    Air Tools & Compressors Logo
    300 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
