Question about Sony KDL32EX700 32 in TV
STANDBY INDICATOR BLINKS 7 TIMES. TV SWITCHES OFF.
pilot210
  • 39 Answers
SOURCE: Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
Posted on May 19, 2009
dsacco86
  • 1077 Answers
SOURCE: 13 standby blinks. Sony KDL-52W3000
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
Posted on Sep 03, 2009
  • 148 Answers
SOURCE: My Sony KDL-40W5500 TV won't switch on: standby
NOOOOOO, do not buy a new one. Your problem , if you fixed it my way yourself, would only cost you around$3.00 to $5.00....
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not) , then please rate!
Thank you.
Posted on Feb 02, 2010
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
chesterpendi
  • 195 Answers
SOURCE: red blinking standby on my sony tv
That problem is cause of faulty power supply board..
look at the capacitors if bulged then try to replace it..
Watch this video to learn more about capacitors:
If you have soldering skills its better to buy a new power supply board online...
Posted on Feb 03, 2012
Media receiver "on" button flashes 8 times and turns the Pioneer TV to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Pioneer Televison & Video
Why does power indicator blink 7 times when switched on?
Sep 04, 2015 | Sony BRAVIA KDL60EX645 60 Inch 1080p...
What causes TV on powering up to go to standby and red standby light flashes 7 times every 2 seconds?
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 12, 2015 | Sony KLV-40V300A 40" BRAVIA MultiSystem...
PANASONIC TV P42ST30B JUST WENT OFF NOW RED LIGHT FLASHES 7 TIMES, STOPS, THEN FLASHES 7 TIMES AND SO ON
Jan 10, 2015 | Panasonic TX-P42ST30B 42" 3D Plasma TV...
Panasonic TH-P55VT30A POWER BUTTON BLINKS 7 TIMES.HOW DO I FIX IT AND WHAT PART DO I REPLACE
Jan 07, 2015 | Panasonic Televison & Video
Standby light blinks 7 times on my kv30hs420 is it worth the repair
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Gopakumar Gopalan Google
Mar 09, 2014 | Sony FD Trinitron WEGA KV-30HS420 30" TV
My Sony tv won't switch of standby just flashes
How many times do this standby light flashes at one time switch ON? Count this and make sure, how many times it blinks. These blinks are fault indications. From these number of blinks, you will get an idea about the faulty section circuit inside it. It will narrow down the troubleshooting. If you wish to get more details about Sony Blinking Codes; check this link.
Feb 17, 2013 | Televison & Video
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDL32EX700 32 in TV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
