Have a Maytag mah4000aww washer and the "brush" that's around the opening of the tub (inside the rubber area) has some brown "goop" in the bristles. This goop is now coming off and getting the the clothing. Any ideas?
  • 15,935 Answers
This felt seal must be replaced. The brown goop is the adhesive.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
I have a may tag Neptune washer model # mah4000aww. When I spin the tub it sounds like there is still water in the washer. Clothes are coming out very wet. Rubber drain is off and little water cameout
When a washing machine drum is removed from the tub after it has been in service for a while a number of objects are often discovered - bra wires, buttons, underwear, coins...
It is possible one or more such items is partially blocking the drain inside the tub.
Sep 04, 2016 | Neptune Washing Machines
Getting lint and scaly deposit on sides of tub even after several cleaning cycles. why?
Check that your water conditioner is working and removing hard ions from your water. Also the scaling you are seeing is likely solidified to the tub surface and needs a more abrasive cleaning method, like a brush with stiff bristles, or even steel wool. Chances were that the water level was high enough for some time to allow the scaling to build up and solidify and thicken to the point where it cannot dissolve with detergents or other chemicals.
Jan 30, 2015 | Maytag Legacy MAV208DAWW Top Load Washer
I have a Maytag Model MHWE300VW11, Serial CSW5002000 and the clothes never smell fresh. There is always a mild sour smell. I always wipe out the washer and wipe all around the gasket in the tub and I...
you could look for a build up of muck- old soap powder etc around the main door rubber, there are places where the muck will collect. put your fingers right inside the door rubber as there are gaps that are hidden . this muck builds up and causes a horrible smell
Aug 29, 2010 | Maytag Washing Machines
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Brown streaks
Remove the water supply hoses and check the small screens inside the ports on the water inlet valve. Make sure they are clear of rust and debris. A common problem is the screens getting rusty and putting the iron oxide into the wash water causing brown stains or streaks to get on clothing and sometimes leaving a brown ring around the tub. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH4000AWW will not drain all the water out.
If you are saying that after the washer has finished you are left with wet cloths and water left standing in the tub ,then your pump is broken or as was my case I opened the back and removed the pump only to find a small piece of wicker that had come off my laundry basket . It was keeping the pump from turning .I removed it put everything back in place and saved over $380.00 . I hope this helps good luck .
Apr 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Neptune mah4000aww belt wont stay on drive wheel
lost you on chat you closed the window
plz email me
Mar 03, 2008 | Maytag MAH6500 Neptune Front Loading...
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
