Question about Xerox Phaser 6250DP Laser Printer
Phaser 6250-Tray 2 continuously ask for A5 Paper
I have tried changing the paper size and type and it will not accept the change. It keeps flashing A5 Paper needed in Tray 2.
    Genius:
  • 2,120 Answers
Adjust the side guides in the paper cassette tight against the paper stack.
Posted on Jan 25, 2009
My Xerox Phaser 6128MFP printer flashes red light after every print out....
First, when you put the paper in the tray make sure the paper holders on the side and back of the tray are positioned against the paper stack but not so much as to be snug.
Next, inside the compartment where the paper try is inserted look for a small plastic piece that hangs below the ceiling of the compartment. It should be near the front of the compartment hanging down and should swing freely backward.
Also, in the printer's paper tray settings make sure that tray is set to that size of paper you are using.
Apr 02, 2015 | Xerox Phaser 6128MFP AllInOne Laser...
My Xerox Phaser 6128MFP printer flashes a red light with a "Load paper in Tray" message, when the specific paper size and type are already same in the tray.
If the paper size is correct in the printer and the printer and it's possible to print off a test print in both the printer control screen or directly from the print driver utilities if that works then the only thing I can suggest is the item you want to print is defaulted to a different size. i.e. Check that the word processor your using is set to the size you have in the printer. Imperial size pages will look very similar on screen as does the A4. Printers don't automatically fix paper print sizes you just have to check and recheck for differences. Removing the tray only reafirms to the printer that the size might be incorrect and your going to fit the correct size.
As for the red light all printers behave differently in certain error conditions. Have you also tried to print out something you printed at a time the printer was working correctly. In other words try printing out a different file. Maybe, trying to print off a test print of one line of the alphabet, and then go from there.
Good luck,
Apr 02, 2015 | Xerox Phaser 6125 Laser Printer
At school there is a printer the Dell 5100cn laser printer and we need to print labels and each time we try it asks on the computer if I want to continue because they are outside of the standard margins,...
A5 is a European paper size standard. Your label making program is telling the printer that the program needs that size label paper. You have to tell the printer to use that size paper. It may be somewhere in the menu of the printer driver on the computer or it may be on the display window on the printer, or it may be as simple as flipping a tab in the paper tray. As far as the printing outside the standard margins, most printers will allow a certain amount of that without a problem. Just tell it yes or Ok. If you solve the paper size problem and it hangs up when you tell it to print outside the margins, then the printer is not compatible with that label format in the label printing program. You will have to choose a different format. I recommend that you select a label format that is a US standard like 3 across on 8 1/2 x 11 paper.
Nov 19, 2010 | Dell 5100cn Laser Printer
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
HP Laserjet 2430n printer won't see the paper in Tray 2. Continues to give in display paper size *letter and *plain but I set it and it just comes back asking again. When you print it won't pickup from...
Yes I checked the tray throughly. I also changed to paper to legal plain and changed the configuration...still came back on the display panel change paper size...just won't stop asking.
If I put the add-on paper tray 500 sheet that tray works fine.
I was thinking though I might order another paper tray and try it since I replaced the pickup assy and still have problems...what do you think
I also cold reset the printer just in the event something was set wrong...still has problems
Oct 15, 2010 | HP LaserJet 2430tn Printer
Xerox Phaser 6250 keeps saying "Insert tray 2." It is pushed in as far as possible. Has the sensor died or something?
check to see if the switch in the printer is not broken,
you can take the tray out and look inside and you will see a switch assembly that corresponds to the printer tray settings. also, look at the papen sensor and see if it swings properly.
if it all looks well, you will need to get a part.
116134300 1 SWITCH; PAPER SIZE ASSEMBLY
Jun 15, 2010 | Xerox Phaser 6250N Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
HP LaserJet 9040mfp All-In-One... Problem
You first need to run a configuratin page from the infromation menu on the printer. It will tell you what size and type paper the printer thinks is in tray 2. If that does not match what is actually in the tray (size) then you may have a issue with the paper size switches on the right inside cavity of the paper tray. If the switches, there is a samll pca board behind the black cover with the 3 metal springs. That board is the same for both trays 2 and 3 so you could switch the boards to see if that is the issue. It could also be as simple as the paper tray bar not aligned correctly and the easy way is to switch trays 2 and 3 and see what happens. The type setting which is inputed at the printer if not matching the job will cause the paper to not be drawn unless that type is asked for. Example if someone changed the type to preprinted and you do not ask for preprinted it will never draw from that tray. Hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=e
n&cc=us&objectID=bpl12037
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en
&cc=us&objectID=bpl10241&prodTypeId=18972&prodSeriesId=1845551
If tray 2 & 3 have same size/type, will pull paper from 3 until empty. Make sure that the tray selection (or paper type) in the printer driver or software application is set correctly. (The printer driver and software application settings override the printer control panel settings.)
Jan 09, 2008 | HP LaserJet 9040mfp All-In-One Printer
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
239 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
