Question about Samsung Dryers
Samsung Dryer Model # DV448AEW/XAA keeps blowing thermal fuse
the dr
  • 447 Answers
SOURCE: Thermal Fuse
First of all stop replacing the fuses and using the dryer it could burn down your house. The problem is the vent is clogged (not necessarily in the dryer) make sure also that the vent flex is not excessively long behind the dryer and is not kinked when the dryer is pushed back.
Posted on Nov 19, 2007
larryyb
  • 291 Answers
SOURCE: thermal fuse keeps blowing
they will blow if the heat dont get out of the dryer and builds up inside / check and see if vent hose behind dryer is kinked or vent going outside is open / it will be one of those two.
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Posted on Mar 09, 2009
  • 382 Answers
SOURCE: how do i fix a belt that slipped off my samsung
There is a tensioner in the pulley that should keep the belt from slipping off.n most cases they work very well at keeping the belt tight.In your case the belt may be stretched too much ,I would check it and replace it if necessary
Posted on Mar 07, 2010
SOURCE: My Samsung steam dryer (model DV448AEW/XAA) has
This is for the ELECTRIC MODEL Only. I have the DV448AEPl and had the same problem... I cleaned all of the lint from every nook and cranny and ordered a "repair kit" from Sears (http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV448AEPXAA/1482/0151200?searchedModel=dv448&blt=) there is even a blow up of the parts there - I ordered part numbers , DC47-00015A, thermostat, DC47-00018A - thermostat and DC47-00019A - dryer heater. The heater is relatively easy to get to if your not squeamish about removing some screws and taking the front off the dryer. Once the front is off you can clean even more lint from the dryer. Remove the heater unit by unscrewing the single screw accessed from the front of the dryer and then disconnecting all of the connectors.
Lastly - once I took the heater assembly out I found that a dime had made its way into the heater coil and was shorting it out... Probably could have got by by just removing the dime and cleaning the coil but I figured that since I was elbow deep in the thing I might as well clean it all up and install the new parts.... Cost of parts was about $80.00 w/shipping. Cost of a repairman to knock on my door here is $150 so I came out ahead on this one... Good luck.
Posted on Dec 08, 2010
My Samsung DV488AEW/XAA Dryer keeps blowing the thermal fuse. It has good airflow; there's no lint buildup. I've replaced the fuse 4 times now and also the thermal cutoff and the heating element. Help
Check the airflow if it is restricted at the output, you need to have the vents cleaned. The airflow is backing up and causing overheating inside the unit.
Oct 15, 2015 | Samsung Dryers
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
Dec 03, 2014 | Samsung DV331AEW Dryer
Does Samsung DV448AEW/XAA dryer have a reset switch ?
If it over heated most dryers use thermal fuses. They must be replaced if they have blown. Samsung is one of the most difficult that I have seen.
samsung dryer not heating YouTube
Searching Model For Search Your Way DV448AEW 4
SEARCH SAMSUNG
Oct 10, 2014 | Dryers
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
I have a samsung dv448aew it powers up but wont start it shows error 1 door open
need to check the door switch and thermal shut off fuse, with a multi meter for continuity.
May 21, 2014 | Samsung DV448AEE Electric Dryer
My Samsung steam dryer (model DV448AEW/XAA) has stopped heating. Everything else is working fine, Is there a user accessible fuse for the heating element or is there a diagnostic it can run to let me...
Nov 15, 2010 | Samsung DV448AEE Electric Dryer
How do i fix a belt that slipped off my samsung dryer model number dv448aew/xaa ?
Mar 07, 2010 | Samsung DV448AEE Electric Dryer
The dryer drum stopped turning.what could be wrong?
That is most likely a broken belt.
I have repair photos HERE
Feb 15, 2010 | Dryers
Dryers Logo
66 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
