Question about Mad Catz TRIUV150 SEE2 UV150 USB TO VGA VIDEO ADAPTER (TRIUV150
Connect a second monitor to windows 8 computer
How do I connect dell ultra sharp 24 dual monitors to dell 9020 mini tower
At the back of the unit you will see a graphics card output. If you only have one then you will need to buy a second one to utilise a second monitor. You will need 2 DVI outputs to run this kind of setup.
Mar 05, 2015 | Dell OptiPlex 9020 Desktop Computer -...
No display
This could be many things
Check all connections.
try a different known-good monitor with same video source (computer), if the second works then the fault lies in first monitor.
If the second monitor does not appear to work, the fault lies with your video source (computer).
In the former case, check power is going to the original monitor. Is the power light coming on ?
Without further information, it not possible to say much more
8.March.2015
Jan 23, 2015 | Computers & Internet
I have an Hp pavilion f1903 19" monitor and it was running fine with windows 8 but now after I turn on the computer and turn on the monitor it flashes on for a second but then goes back in sleep mode.
It doesnt seem like its a driver issue. Make sure windows 8 is updated. If you are fully updated, it should be updated to 8.1. This is a free upgrade when you have 8. Are you using an HDMI connection? Check the cable on both ends or replace with a good one to see if it does the same thing. Does your monitor have a usb data port on it? Look fir a firmware update. If not, or yes updated, but still the same then I would suspect a few bad capacitors on the LCD's power supply. You can see the bad ones that have domed tops or leakage. get the value of them, get replacements. You have to know about polarity and electronic soldering. Good luck. Hopes this helps.
Jan 22, 2015 | HP Computers & Internet
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
I am trying to connect a second monitor a dell E173FP to my computer. I run Windows 7. My computer is not detecting the second monitor.
If you have a dual-head video card, you will need to go into display properties where you should see 2 monitors. One will be grayed out. You need to right-click on that one and tell the computer that it's connected. Then you can set it up.
Oct 27, 2011 | Dell E173FP 17" LCD Monitor
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only...
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
Jan 03, 2011 | Acer X163W 16" wide format TFT Screen 8...
Black screen on my LG Flatron lcd 563le
I solved the problem myself by disconnecting the monitor from the computer and then I unplugged the computer. I restarted the computer in position fail safe (F8) and tried to change the monitors resolution back to origin, failed to do so and rebooted instead. When Windows loaded up the problem was gone! Yipeyiiiii!
Bjorn
Jun 02, 2009 | LG Flatron 563LE 15.1" LCD Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Nov 09, 2008 | Acer X193W LCD Monitor
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Mad Catz TRIUV150 SEE2 UV150 USB TO VGA VIDEO ADAPTER (TRIUV150 Logo
75 people viewed this question
Top Mad Catz Televison & Video Experts
Electro Med Services...
Are you a Mad Catz Televison and Video Expert? Answer questions, earn points and help others
