Question about Belkin (F5D7230-4) Router (587009)
How do i change the channel on my router
I have a desktop computer that is working just fine. When i connect to the internet with my laptop via the wireless router, my laptop is moving slow. The cable guy who i get my net service from said that i probably need to change the channel that my router is on from 2 to 11. Could someone please tell me how?
Put in the disc again and run the installation and when it asked me to run the installation it asked me what channel I wanted it on but the default was 11 so I kept it there, just try to set it up again
Posted on Jan 28, 2009
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
I have a Virgin modem & d link DIR 615 router. I am connected to my desktop via ethernet cable which connects to the internet ok & works fine. I wish to connect my wife & son's laptops...
Hi
while your computer connect to the internet so the connection is good ..
but in other laptops please do that change IP mode to the DHCP Mode or give IP in the same network
try to click repair
Apr 25, 2011 | D-Link DIR-655 Wireless Router
I have 2 computers - a desktop without wireless and a new laptop with wireless. I want to connect the Belkin N150 basic wireless router to both these computers. I have introduced a "wired"...
WIRELESS SECURITY ISSUES
UNINSTALL THE BELKIN ROUTER MANAGER FROM THE LAPTOP
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP ( WPA WILL NOT WORK )
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2010 | Belkin Basic Wireless Router
When initially setup the router worked fine. However, after a computer crash and re-install, the desktop pc cannot find the router even though it is connected by Ethernet. Laptops will connect to the...
Dec 09, 2010 | Belkin Wireless Play Router (F7D4302)
My router is suddenly not working. The internet, modem, router and the wired lights are on, but the wireless and security lights aren't on and I can't connect from my laptop wirelessly.
check the wireless settings of the router.
Open the set up page of the router and make sure that the wireless SSID broadcast is enabled.
If enabled then try to change the wireless channel of the router.
if that doesn't work then try to upgrade the firmware of the router.
Click Here for more info about routers
Dec 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Laptops connect to router but still cannot get on internet
It's just a wireless interference problem. All you need to do is change the wireless channel of your router. Login to the router's admin page and look for wireless channel under the WIRELESS tab. Change it to channel 11 and save the settings. That should solve your problem. You can play around with different channels and check which one is the best for your environment. Good Luck!
May 07, 2009 | Linksys Wireless-G WRT54G Router
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Speeding up internet
Here are a few suggestions on how to speed connection:
- Move router or pc location if possible. Closer = better connection usually
- Try changing the channel your router is broadcasting on. Sometimes there are slower channels and faster channels in heavy traffic area
- If you have any toolbars in your browser (i.e., yahoo or google), remove them. Those toolbars use up resources that can slow you down.
- Delete cookies and internet files
If these don't work, post a comment on here with your operating systems on laptop and desktop and router type.
May 14, 2008 | E-Machines eMachines Desktop PC
Internet connection
hello!
1. what is the model number of your wireless adapter?
2. what is the operating system of your computer?
3. how far is the laptop from the router?
-- try to change channel on the router
-- try enabling wireless security on the router and on the wireless adapter
-- diable other 3rd party firewall on your laptop
Apr 14, 2008 | D-Link DI-634M Wireless Router (DI634M)
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Belkin (F5D7230-4) Router (587009) Logo
346 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
