Question about Motorola Mobility Original 89358n Tk30 Bluetooth Stereo Handsfree Car Kit Speakerphone
Mute wire configuration for motorola tk30
Just wanting to know how the wiring is configured to mute the speakers
2 Suggested Answers
  • 2559 Answers
SOURCE: Motorola Razr v3 stuck in mute mode. Finally find mute switch during a call, turn it off , says mute off with green arrow and then it reverts back to mute!
Back up your data and do a factory reset. You will lose all data but this usually will fix this issue.
Posted on Oct 10, 2016
How to fix mute
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it in XP
right click on the speaker icon in the bottom toolbar select playback devices should be a green tick in the speakers if not right click select configure also check the communications tab make sure the are not muted
hope it helps W7
May 28, 2012 | Samsung T220HD LCD Monitor
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Corner of the radio is flashing ATT
ATT is like a mute option, hit mute or ATT button to return to normal operation.
May 15, 2012 | Kenwood KDCX895
I have an audi a3 2005 but my CK3100 wont mute when taking calls??
Has your 3100 ever worked correctly since being installed? Can you give me more information about how it was installed (professionally or by your self)? Often times when these are installed the mute wires get connected (Mute 1, 2, and 3). These are unnecessary and will often cause problems because many stock radios don't have a dedicated mute wire. If you are able to get to the wiring disconnect and tape up the mute wires. Did that solve the problem? If not and if this also came on after a time where the Parrot worked correctly, it could be the blue box or the mute cable (the one with the wires that go to and from all the speakers with the black box on it) have gone bad. I've installed many of these without issues. I've also had to replace brand new ones after people installed them and connected the mute1, 2 or 3 wires. If those mute wires are connected to the wrong wire in the vehicle it can allow current to flow into the device causing it to damage itself damaging itself.
Let me know if this has been helpful
Ray
Mar 01, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How to wire my parrot ck3100 into a sprinter van can u give me the wiring diag as i dont have any connectors on my parrot kit as its from my old car im having trobule with the mute wires and speaker...
First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Aug 03, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My Dell Inspiron 6000 stopped playing sound. I uninstalled and reinstalled SigmaTel driver. This did not work.
Does it show that the device is working properly in the device manager? You could try and use system restore to roll back windows to a time when the sound was working. Windows may have updated software and caused problem with audio. If you roll back the system to a time when you know the sound was working then the on board audio may be defective. Have you tried plugging in headphones in the headphone jack and check if there is sound? Are the sound properties muted? The laptop speakers or internal amp may have stopped working also.
Sep 10, 2009 | Dell Computers & Internet
'Yellow Wire - Stereo Connection???'
Yellow wire connects to the music mute wire on the back of the car stereo (usually brown). This will mute the stereo when the hands free is in use!
May 28, 2009 | Sony -Ericsson OEM HCB-300 Bluetooth...
Mute option
Mute can only be done on the speaker phone. It is done by pressing the MIC button , it can be configured as a toggle or a press and hold. Your manuals and guides are here
http://guides.idacomusa.com/
Feb 23, 2009 | Toshiba DKT-2020-SD telephone
Trying to add speakers
The only way i can see of feeding two sets of speakers from the one pc would be to buy or make up a "splitter" audio lead .....i.e a 3.5mm stereo jack on one end connected to the pc with two lots of wiring going to 2 3.5 mm jacks. I don't know whether a store like Maplins would sell such a lead. Are you any good with a soldering iron??
Dec 31, 2008 | Gateway GT5468 Desktop PC
Jensen vm9511ts cuts out
It sounds like the phone mute is going on and off, but I'm just guessing because I don't know your grounds, speaker wire hookup configuration, etc. Look at the screen when the music cuts off and goes back on and if you see a little red phone with the cross through speaker symbol (aka mute) it's probably the phone mute feature which is supposed to be hooked up to bluetooth and mute the stereo when you get a call. Like I said I'm just guessing, but if so there's a brown wire in the back that needs to be hooked up.
Jun 19, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Motorola Mobility Original 89358n Tk30 Bluetooth Stereo Handsfree Car Kit Speakerphone Logo
64 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
