Question about Lincoln 1132000U - Impringer II Express Conveyor Pizza Oven, Front Loading, Single Deck, 120/208V
Can i use a connector to the element thats rated for 170 degrees
  • Lincoln Master
  • 744 Answers
Hello Jack;
My name is Peter. I am a retired field service appliance technician.
Although I am retired I do work on the side.
Connectors have different ratings. If you go into a Lowe's or Home Depot Store, you will see the connector packages are rated with the temperature limit. I like to carry connectors that are rated for 250 degrees F. They cost a little more. I like to play it safe.
Ask the person in the electrical department for assistance to make sure you get the correct connector.
Posted on May 17, 2015
  • 106 Answers
The connectors are usually made of materials that cannot withstand high temparatures, unless the conector you want to use are rated for high teparature above your oparating temparatues
The best thing to do size down the element about 1/2 inch carefully with arcsaw. Then coil the protruding element such that you can use bolt and nut to fasten wire to it.
My Top Oven will not heat above 170 degrees and it talks a long time to reach that temp.
either the heating element has a hot-spot on it or the oven sensor temp rod is defective
Sep 08, 2012 | Ovens
Wires disconnected from elements
that happens,, they burn off after a while,, you can get heat rated connectors and replace them yourself with those connectors and a crimp tool, using connectors that are not heat rated for a range or stove will just burn off as soon as you try and use them,
Sep 02, 2011 | Ovens
Replace botton oven alerment
not knowing the make and model of your oven I can give you a basic description of what to do , first unplug the oven, I'm assuming that this is a electric model, ( if its gas, Just lift up the burner element and remove) next you need to remove the back of the unit,, so that you can get access to where the element is attached to the electrical connections, (if you haven't done this before, you may find out that the connection has just burned off the wire, and you can just replace that with a temperature rated connector end, they just crimp on ) if the burner needs to be replaced, remove the 2 connectors,, and inside the oven you will probably have a few clips that hold the element i n place,, Just pop them off, you will use the same ones on the new element , pull the element out through the oven,, and replace the same way , be sure and use care when tightening the connections , they will break off pretty easy,, but snug them tight , replace the back cover,, plug it back in, and enjoy
Jul 24, 2011 | Ovens
I am replacing the Thermador bake element in model CMT 21. I have turned off the breaker and removed the 3 screws on each end of the element. I pulled the element forward exposing the wires attached to...
if the wires are pushed onto the element get a pair of needlenose plyers and grab the connector and slide it off,if it has a screw holding the wire connector on remove the screw and slide off the connector,you're looking at it if the connector just slides off then pull it off and connect it to the new element,but first did you check the element to see if it was good?very simple to do check it for continuity,get a multi meter set it to 20k ohms with the power off of course,remove at least one wire off of the part you want to check,you should see a 1 on the screen,touch the leads together you'll see anything but 1 NOW PUT YOUR LEADS ONE ON EACH SIDE OF THE ELEMENT WHERE THE WIRES CONNECT TO IT AND MAKE SURE AT LEAST ONE OF THE WIRES ARE REMOVED,IF YOU SEE 1 THE PART IS BAD OR OPEN IF YOU SEE ANYTHING BUT 1 THE PART IS GOOD OR CLOSED.you can't get most parts for these older ovens so if the element reads good the element isn't your problem it's in the board and most likely you'll have to replace the oven unfortunately,also when you put the new element in set it to 170 and make sure the element cycles off when it reaches temp. the element should stop glowing orange when it does reach temp.if it doesn't you can't get any parts for this model.the only parts you can get is the elements.good luck with your repair,hopefully it will just be the element.
Jan 19, 2018 | Thermador Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
St George DEO 7 oven temperature not going past 170
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Sep 06, 2009 | Ovens
Cleaned oven, now baking element not working-element is good-buzz
This F-3 is concerning a Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control.
Solution--
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jun 16, 2009 | GE Profile JTP18 Electric Single Oven
Heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Mar 01, 2009 | Ovens
Stove won't go below 170
The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Lincoln 1132000U - Impringer II Express Conveyor Pizza Oven, Front Loading, Single Deck, 120/208V Logo
62 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
