Question about Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler,
Lower temperature zone in whynter wine cooler stays too cold
We have a two zone Whynter wine fridge. The lower zone seems to stay between 48-50 degrees F even though the thermostat is set much higher than that (low 60s). I'm guessing the thermostat is broken in some way. Any idea how I can fix it without hiring a refrigerator repair guy to look at it?
Why dose my water freeze and dosent come out ....i have to unplug for it to unfreeze then it freezes again after i plug it back in
I am thinking this is not a cellphone you are talking about, but a water dispenser?
The thermostat is set too low. You need to UP the temperature a couple of degrees.
Aug 03, 2016 | GE Profile PXCF22RBS Hot and Cold Water...
I have a frigidaire pro FPHS2386L and the freezer is too cold. Any ideas?
George makes a good point but I'd like to add that there is generally a fan that blows the air between the freezer into the fridge area. If there is no obstruction, the fan most likely needs to be replaced. On a few models this can be done with a little patience and a screw driver and the fan part. Check with a Sears Parts distribution store avaiable around the country for the part if the model is carried by Sears. If not, Google the fridge make and model number with Freezer Fan Replacement.
Nov 23, 2014 | Frigidaire FPHS2386L Stainless Steel...
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
I have the Renewaire Energy Recovery ventilator system, Model EV130, installed in my house but do not know how to set it to the proper setting. The runtime numbers go from 10 to 100 and I am not sure what...
The RenewAire system is sized per ASHRAE 62-1999, residential air exchange of .35 air changes per hour, or 8 air changes per day. You can find an operation sheet for the PTL @ www.renewaire.com, downloads, residential, controls, PTL. A chart shows a starting point of ventilation based on the square footage x 8 foot ceiling height with a run time percentage for each model. For 2250 square feet with 8 foot ceilings, the run time for an EV130 is 85%, cycling hourly.
Actual run time will vary by tightness of house, number of occupants, lifestyle (number and frequency of pollutant generating activities). Outside weather conditions should have little effect on run time percentage. I run my system @ 50% year round, when the windows are shut.
The ERV tempers humidity and temperature extremes of the ventilation air year round. It is not a substitute for heating or A/C; it does not dehumidify the house in summer (it does reject some of the incoming summer humidity content, when the net humidity is greater outside than inside). It will lower humidity of the house in winter, or whenever the net humidity outside is lower than inside.
It will ventilate the house in an energy efficient manner all year long. Based on this information, choose a setting and manage the amount of run time to achieve your best IAQ.
Apr 25, 2009 | Air Purifiers
Cleaned the plates and the back filter and went to turn it on and it will not turn back on
Be sure the tab on the filter is making the safety switch click in and stay in. Sometimes, all you need to do is push in on the lower right corner a little and it will start.
Mar 25, 2009 | Alpine Air XL-15 Air Purifier
Water Cooler Problem
you might try a strong solution of vinegar and water and then flush it later till it tastes right
Mar 09, 2008 | Air Purifiers
Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler, Logo
61 people viewed this question
Top Whynter Air Purifiers Experts
Are you a Whynter Air Purifier Expert? Answer questions, earn points and help others
