Question about Vector Camping, Backpacking & Hiking
Need lead-acid battery for VEC 1369 rechargeble lamp
4 Suggested Answers
  • 973 Answers
SOURCE: need battery -DMU 6-6
You can order one from Black and Decker, they purchased Vector in 2006 and have all the parts you need, here is the link; http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
CarlGlas
  • 283 Answers
SOURCE: I need a replacement for
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Posted on Aug 12, 2010
  • 172 Answers
SOURCE: i need a lead acid
If you pull the battery, you should be able to match it at a battery specialty store like BatteriesPlus or The Battery Store (both are chains in my area that sell specialty replacement batteries). Someone there should also be able to suggest alternative batteries if an exact match can't be found. It's almost certain that multiple manufacturers make a battery with comparable voltage and amperage characteristics; the finicky part is finding a battery that has the right terminal placement.
It's worth looking at substantially similar batteries. Sometimes, a battery with slightly different terminals will cost a fraction of the price of an exact match. If that's the case, it may be worth your while to engineer a little adapter wire so you can use the cheaper alternative in your light.
On a final note, once you know the standard description for your battery, you can often find the cheapest replacements online. Speaking generally, this size lead-acid battery is used in many UPS devices, though those cells may have different terminals. However, if you go shopping online, be aware that the cost to ship a lead acid battery may eat up any savings in price from shopping locally. In addition, if there's a problem with the replacement battery, it will be more difficult and more expensive to return/exchange it than if you purchase one from a local shop.
Posted on Jul 13, 2011
VETERANS HOME JUST GAVE ME A USED QUANTUM WHEELCHAIR AND PRIDE MOBILITY CHARGER. HAS AGM BATTERIES. CHARGER MODEL EA11488 SAY LEAD ACID BATTERIES ONLY ????
AGM batteries( absorbant glass mat ) batteries have a different charge rate to ordinary lead acid batteries
it is all abiut the charging rate or charging volts so the charger you have may not be suitable for the AGM batteries in the chair
the difference in the lead acid battery and the AGM battery is the construction
Lead acid batteries will spill acid if tipped over where as a AGM the acid is absorbed in the glass mat or is an acid gel
to get a read of what it is all about go www.batteryuniversity.com and you will see what I am refering to
next best thing is to ring your local battery shop and ask then what charger you should be using for AGM batteries and if a normal lead acid battery is suitable for the job
Jan 24, 2017 | Pride Health & Beauty
What is the chemical reaction that take place in the lead acid battery?
the sulphuric acid reacts with the lead in the plates with the result that the acid breaks down and tends to go water and the lead becomes lead sulphate
when a battery is dead flat, the plates are all lead sulphate and the density of the acid is approaching that of water
that can be tested with a hydrometer
When a charge is applied to the battery terminals , the process is reversed and the lead sulphate returns as lead and the water ( low ph acid) returns to sulphuric acid
Mar 05, 2016 | Cars & Trucks
I need to replace a fifutec sealed lead-acid rechargeable battery [12v -2.8ah]
http://www.atbatt.com carries a large array of sealed lead acid batteries. I did a search for 12V 2.8ah and here is one of the results:
http://www.atbatt.com/sealed-lead-acid-batteries/b/interstate/m/interstate-12v-2-8ah.asp
May 22, 2015 | Camping, Backpacking & Hiking
My Vector model #VEC117FS has a battery that is dead and will not recharge. The replacement battery is VEC 191 according to the owner's manual. Where can I buy this battery or is it best to just buy a new...
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Nov 10, 2010 | Vector 1 Million Rechargeable Spotlight
There is steam and a strong egg smell coming from the battery. What is the problem?
This is a high charging on the battery, as it is overcharged . this can be failure of the alternator rectifier or the regulator.
so use a voltmeter and confirm the voltage range to rectify the fault.
A high charging of this nature can damage the battery in the long run.
Sep 25, 2010 | 2006 Chevrolet Avalanche
Need a dmu 6-6 6V6AH Battery. For vec 127Y Super Sport Spot. Where can it be purchased & how much?
Try www.batterymart.com
www.batterymart.com/c-03-6-volt-sealed-lead-acid-batteries.html
Jul 03, 2010 | Vector 2M Pwr Rch Spotlight
I purchased a VEC142 worklight and cant get it to charge. This light is brand new. never been used. I returned the first one i purchased for the same reason. and i cant figure out why it wont work. I do...
The battery is dead, even new lead-acid batteries can be no good if they have been sitting for awhile, you can contact Black and Decker for Warranty or to purchase a new battery. Here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?r=No%20%Results
Jul 04, 2009 | Vector VEC 142 Rechargeable High Intensity...
Battery charger
Most lead acid batteries can be charged with a boost, this can be 10 AMPs, but normally have a current sense circuit so when the battery reaches it knee it goes into a trickle charge.
Jul 18, 2008 | Computers & Internet
Batteries
I have the same player as pictured, bought if from Best Buy, and even they don't know where to get them. Idiots! Current lead is Batteries Plus, just google them
Jan 16, 2007 | Audiophase CDM450 Personal CD Player
Camping, Backpacking & Hiking Logo
70 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
