Question about Nokia Asha 201 Gsm 850/1900- Graphite unlocked- Factory Seal-
Nokia hardware Id missing - Nokia Asha 201 Gsm 850/1900- Graphite unlocked- Factory Seal-
Hardware id missing
Get in touch with Nokia (Microsoft) support at: http://www.microsoft.com/en-us/mobile/support/
Jun 19, 2015 | Nokia C101 Cell Phone
Hardware id missing
I got that error when my IDE to USB cable went bad. Although it could also be bad/corrupt drivers. Can you put the drive on an IDE cable to check it inside a computer without the USB?
Feb 24, 2014 | Toshiba MK6026GAX 60 GB Hard Drive
Nokia c1-01 hardware id missing
how to solve the problem of hardware id missing in nokia c1-01 tell me please
Sep 12, 2013 | Nokia Cell Phones
Multimedia audio controller
This indicates that the sound drivers are missing from your computer. You will have to identify the sound card that is installed on your computer before proceeding with downloading the correct driver. To identify the sound card, follow the steps below (Assuming that you are using Windows XP)
  1. Open Device Manager (Right-click My Computer>Properties>Hardware>Device Manager)
  2. The hardware whose drivers are missing will appear as Unknown device, so it’s easier to locate the device.
  3. Right click on the unknown device and click on Properties.
  4. Under the Properties window click on Details tab and select Device Instance Id from the drop down box.
  5. You should see a code similar to this
    PCI\VEN_8086&DEV_27DC&SUBSYS_30868086&REV_01\4&1E46F438&0&40F0
  6. The portion of the code highlighted in RED is the Vendor ID and the portion highlighted in GREEN is the Device ID. In this example:
    Vendor ID = 8086
    Device ID = 27DC
  7. Once you have obtained both the IDs, proceed to www.pcidatabase.com . There you can either search for the vendor from the vendor ID or directly get information about the device along with the vendor name by searching with the device ID.
Mar 25, 2009 | Acer Computers & Internet
Master code
Mastercode:
This is the code needed to reset the Security code, nothing else, and it's for your phone only. You type in security codes until the phone request the Mastercode, when it does, leave your phone still, don't use it for 15 minutes, then type in the Mastercode.
To give you your Master Code I need the IMEI number to get this type *#06#
Jan 18, 2008 | Nokia 6300 Cellular Phone
I dont hv a hardware of nokia phone
here's my link for nokia pcsuite
download here
peace!
Nov 26, 2007 | Nokia 7610
Nokia mobile
Blue tooth ID as to be read by entering the code *#2820# if u recieve any id then small reflow is enough on the BT Module(Hardware). else the same has to be replaced
Sep 02, 2007 | Nokia 6600
Nokia Asha 201 Gsm 850/1900- Graphite unlocked- Factory Seal- Logo
371 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
