Humidifiers
Problem for Humidifiers
Generic problem for all Humidifiers
Water does not pass through solenoid
By maeady13 on Jan 25, 2009
Newer < 2 years. Water supply line is ok. Wiring at solenoid,at humidistat, and at furnance are intact. My guess is that automatic humidifer control or solenoid are not functioning - How do I determine which?
Solution #1
posted on Jan 25, 2009
Not Rated)
mrgrzz
Rank: Guru
Rating: 93%, 29 votes
Thanks for your question,
first you need to determine if you have 24 volts from the transformer, if you have knowledge of electrical meters then this should be fairly easy, if not then you will need to do a little rewiring to find out if it is the solenoid, first you will need to do is shut the power off to your furnace, then get some t-stat wire, long enough to reach from the solenoid to the transformer, splice together the new wire to the wire from the solenoid, now take the other end of the wire, take the leads off the transformer (low voltage side) and hook the new leads to it, make sure the water is on, now turn the furnace back on, and if the solenoid is good the water will flow, if it doesnt, then you will need to replace the solenoid, if the solenoid does work then you know your problem lyes with the Humidistat, and you will have to replace that, but you need to determine if you have 24 volts from the transformer first, hope that helped, let us know and please rate this, thanks again ,
mr.grzz
Was this helpful?
Yes
No
Popular Solutions for Humidifiers
Questions and Unsolved Problems for Humidifiers
Answer
I have a Lakso model 110 humidifier that needs a filter. Can you advise me where I can find... (More)
Answer
Hi, Could anyone please recommend filter free cool mist humidifiers (3-4 gallon). I am sick of... (More)
Answer
I have a Honey well HCM-6009 humidifier, the water tanks are full and operating properly, I put new... (More)
Answer
my job is village trasforable job inconvinient for facility so i reqire portable battery operated... (More)
Answer
motor runs constantly even with digital control reading off and both empty tank lights on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Humidifiers:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
