Question about Pioneer Televison & Video
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
I have a pioneer XV-DV151 and it shows OC ERROR. how to fix this>
    New Friend:
While stad by bottan pressing oc error coming on display
Posted on Feb 26, 2013
Help me guys regarding my home tieter pioneer model xv-dv 272 .my problem is When I open my player the display is only oc error1 I don't know what kind of error code is this help me guys pls reply
Unplug the power then hold the power button down and plug the unit in again to reset it. If not this is probably a component fault.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 03, 2017 | Pioneer Televison & Video
What is the solution to an error code ( OC ERR 1) ON PIONEER XV-DV360
The "OC ERR 1" code is a sign that there is something wrong with the speaker connection(s). Mostly one of the speaker cables is causing a short-circuit, which triggers the safety system. Power off the unit and pull out the plug. Check all the speaker connections (amplifier and speaker side) and make sure that no (parts of the) cable is (are) touching the chassis. Twist the cable ends to a single core if necessary.
Jul 21, 2015 | Pioneer Televison & Video
Timer blinking
Turning the record timer on/off
  1. 1 Press TIMER/CLOCK ADJ.
  2. 2 Use the <> (cursor left/right)
buttons to select REC.
On the front panel use '<<>> and <<>>'
  1. 3 Press ENTER.
  2. 4 Use the <>(cursor left/right)
buttons to select ON or OFF.
5Press ENTER.
Apr 20, 2014 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
When I turn on my pioneer xxd3121, it's showing only OC ERR I. How can I resolve the issue?
Go to the pioneer site and either contact them for tech support or download a user manual.
Apr 08, 2014 | Pioneer Audio Players & Recorders
Airbag error 16
Flash code 16 can have several different possible causes.
It is for the Occupant Classification Sensor (OCS) system, as well as the passenger seat belt tension sensor..
Possible causes"
> OCS module internal fault
> OCS module calibration fault
> OCS module sensing element fault
> OCS module communications fault
> Front passenger belt tension sensor circuit fault
You need to pull Process Identifier (PID) codes to know which area to took for the fault.
Flash code 16 can be broken down into a smaller area of possibility with the PID code "B2290" and the symptom code (xx) following.
> B2290(24)
> B2290(25)
> B2290(26)
> B2290(27)
> B2290(29)
> B2290(31)
Getting a flash code 16 can also be a combination of faults that will show up as combinations of PID codes.
May 29, 2012 | 2002 Jaguar X-Type
OC ERROR in pioneer dvd player
read the use guide to get correct error and fix it
Apr 25, 2011 | Pioneer AVIC-N2 Car DVD Player
Pioneer oc error 1
it's output power amplifier problem pls check and change ur faulty ic
Oct 17, 2009 | Audio Players & Recorders
Televison & Video Logo
407 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
