Question about Remington Electric Pole Saw
What causes the chain not to move - Remington Electric Pole Saw
How can i stop the noise from chain set?
hi there is your chain in good condition or worn out ,is the chain dry and needs oiling or is it incorectly adjusted for the bike ,or is the chain out of aliagnment these would all cause noise problems ,or if the chain has been replaced before is it the right size for the sprockets ,and are the sprockets in good condition ,to check if the chain is stuffed move the chain sideways left to right of your bike and if it moves more than a sixteenth of a inch it is worn out .hope this helps cheers
Apr 23, 2014 | Yamaha YZF-R15 Motorcycles
Dewalt 3750 won't allow me to pull the chain to
Loosen the chain so it can be carefully moved by hand. If it moves pull out the spark plug. Sometimes oil and or fuel will collect in the cylinder and will cause this.
Jul 06, 2013 | Garden
1995 Olds Silhouette rattled badly, died while running
I think you had better have a local shop inspect this for a failed engine connecting rod.
Aug 23, 2012 | Oldsmobile Silhouette Cars & Trucks
Chain won't move after chain replacement
Had this happen to mine when I was limbing stuff that was too small. I know better. There is probably a burr on one or more of the guide portion of the links where they run in the bar. This causes that link to be tight in the bar at this point. The chain probably hit something on the body of the saw when it flew off. Take the bar off the saw and run the chain through the groove in the bar. If you have any links with nicks, they will bind, causing the chain to stick and not run freely. Once you've identified the problem links you can remove the nicks using 120 grit paper backed up with a flat piece of steel so you only remove the high spots.
May 05, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
When I cut,the kerf curves to the right.I am thinking the bar is worn out allowing the chain to move or the sharpen is lop sided.What do you think?
While it is possible that the bar is contributing to this problem, the usual cause is uneven sharpening of the chain iteself. The side toward which the chain moves is the sharper side and is cutting moredeeply than the other. The easiest way to prove this is to replace the chain with a new one. If the bar is the problem, the new chain will behave the same way.
Dan
Dec 03, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
I have a poulan woodshark p 3314wsa it starts and runs, but chain doesn't turn
Does the chainsaw seem to rev up without any resistance, or does it bog down as you push the throttle? If it revs up quickly, then it sounds like the clutch plates may be frozen - usually due to rust. If it boggs down, then the chain and/or clutch housing are frozen or stuck somewhere.
The chain drive uses a centrifugal dry friction clutch with two weighted plates that are spring loaded. The springs keep the plates disengaged from the clutch housing to allow the engine to spin freely at an idle (or slip when the chain slows down due to the blade binding).
When you press the throttle, the engine revs up and the higher RPMs create centrifugal force causing the clutch plates to push outward - fighting against the springs, and begin creating friction on the inside of the clutch housing. If rust prevents the clutch plates from moving out to cause the necessary friction, the clutch housing (and drive gear which is permanently affixed to the housing) won't spin and the chain won't move.
With the engine OFF and cool...first take a thick towel or rag and place it over the chain with the engine switch in the OFF position. Try to move the chain in the normal rotation (top forward, bottom backward) to see if the chain moves freely or if it is stuck in position. If it does move, then take off the chain cover and then get a can of PB Blaster and spray the clutch plates and springs. Give it an hour or so and then take a rag and wipe off the excess and reassemble and try it. The excess PB Blaster will burn off with the heat of the clutch and the rust will no longer be a problem.
If the chain won't move, then somewhere along the drive the chain or clutch housing are stuck. Look for a bend or kink in the bar where the chain rides.
May 29, 2010 | Garden
Chain brake is jammed, chain will not move when cranked
Take the side cover off of the clutch area and watch while you try to move the brake. Something may be broken or out of place. If the brake band which is fitted around the clutch drum is damaged, it may be causing non-release.
May 13, 2010 | Homelite ZR10926 16 Chain Saw
Chain not moving
Perhaps. The chain and bar get very hot, sometimes causing the chain to bind, there is a reason for the bar oil reservoir. You may have burned out your clutch. Your chain may be excessively tight. I suggest you find a neighborhood chainsaw seller/mechanic and pay for a quick inspection. While there ask for a 10 minute instruction on how to use your saw. Purchase of a complete set of personal protective gear sounds like a good idea too. HTH
Lou
Sep 17, 2009 | Homelite Garden
Chain brake problem
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
This is the breakdown of parts for your model,you can see how the brake is, but your problem sounds like the dogs inside the clutch are stuck and causing the chain to constantly engage the chain.
Open the clutch to look at it and see what is causing this.
The idle usually will not cause the clutch to engage, this is usually
a higher rev that engages the clutch.
Apr 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Saw is running, but chain is not moving
If you rev the engine and the chain does not spin, either the chain is jammed, or is adjusted to tightly on the bar, or the centrifugal clutch is malfunctioning. With the engine off and leather gloves on, see if the chain will move on the bar, you should be able to move the chain 4 or 5 inches. If you can spin it, the clutch is probably bad. If its stuck, take the housing off over the clutch and make sure the chain is seated on the sprocket and not jammed to the side. Inspect the chain on the bar, there should some slight play in the chain tension. Look for any links that dont flex. This happens to be cause I overtighten the chain to the bar.
Dec 22, 2008 | Homelite Garden
Remington Electric Pole Saw Logo
19 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
