Question about Dell Dimension E521 PC Desktop
Black screen Help!!!!!!!!!!
Switch on computer, it starts but won't boot, replaced the hard drive, same problem, computer starts, blank monitor with just a _ in the top corner and an amber light on the mother board.
    Master:
  • 474 Answers
Most likeley a motherboard failure. I have alot of HPs at work that do this. The connector for the hard drive on the mother board fails and it will do this.
If thers any kind of warranty, I would contact the manufactuirer first.
Asuming though that it isnt, then I would say, try to find a spare parts one online for cheap that has a good MOBO and change it out.
If you remove the Hard drive and try booting wihtout the Hard drive in, do you get the BIOS or SPLASH SCREEN?
Also, try removing any other add in devices to be sure that they arent causing any issues. I.E. the CD DRIVE, ANY PCI CARDS ETC.
aLSO, YOU COULD TRY REMOVING THE BATTERY AND PLUGGING THE LAPTOP IN AND STARTING IT WIHTOUT THE BATTERY IN.
If it starts with just the power adapter but no battery. then its definatley a bad mobo.
Let me know how it goes.
Posted on Jan 25, 2009
Why won't my notebook display any picture on the screen or anything
I assume your screen is completely black and maybe doesn't show the flashing cursor? It could ether be the graphics/video chip at fault, or a hard drive or motherboard fault. It could even be the screen itself.
Does it sound as if your laptop is actually booting up, even though you can see nothing on the screen?
If you can, connect your laptop to a computer monitor (a cable will be required). If your display works on the computer monitor it's probably your video/graphic chip at fault.
If the screen is still black after connecting to an external monitor the chances are that it is a hard drive or motherboard fault.
Don't rush off and buy a replacement hard drive and motherboard. It makes more sense to take your laptop to a shop, pay for an inspection and they will tell you exactly what the fault is.
Jun 09, 2013 | Acer Aspire 3000 Notebook
My averatec will not turn on
Open it again and make sure you connect all the devices and such ..It seam to be like a clear case of a disconnected cable ..If the system boot up ..and seam to run ..try to see if the vga secondary monitor brings anything to a screen ..if it does it means you messed up with the monitor connections ..cause you changed the hard disk ..you don't have a operation system to boot into and try to make an idea..but its a start ..
Other things to check is the fan connections and cables ..
If the screen is totally blank I think is like I said just a bad connection to the monitor or a damaged cable in the process of opening it .In any other case you would have at least a warning on screen even without hard disk it should boot to BIOS ..
Dec 07, 2011 | Averatec Computers & Internet
Each time I start up the computer, it only shows a black blank screen with a cursor blinking on the top right corner of the monitor
That usually happens when the computer is booting up from another drive other than the hard drive... Try pressing delete when the computer start then make sure that hard drive is selected as the primary..
Sep 09, 2011 | HP Compaq dc7600 Convertible Minitower PC...
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
Monitor is black. How do I fix it?
if the monitor led indicator is amber and and the hard drive (usually red) indicator on computer is blinking red. that means your computer is working but onboard video is dead. if under warranty, bring it back for replacement or repair.
Sep 23, 2009 | E-Machines eMachines Monitor E15T4
Dell d520 monitor goes blank while booting up(goes blank when starting windows). Everything boots up(I can hear the audio in the background)except its a black screen. I tried all safemode possibilities but...
just had this experience myself on a smasung monitor. I originally thought of power management but Samsung assure me it is a monitor sync problem and have yaken it away. Theyhave replaced the monitor. So conclusion is that your monitor is also in need of repair
Aug 19, 2009 | CMS PRODUCTS 80GB 7200RPM NB HD SATA-DELL...
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Sep 19, 2007 | Toshiba Satelite 5205-S505 Notebook
Dell Dimension E521 PC Desktop Logo
100 people viewed this question
Alun Cox
