Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Chain brake will not release (homelite chainsaw)
Where can i get parts to repair same
  • 2,176 Answers
The header says you have a Homelite saw and if this correct you can go to Homelite.com and look up parts or other information that you might need for your saw. There is also a contact us area. Good luck
Posted on Feb 18, 2009
  • dpaynter2002 Jul 28, 2011
    I went to their website and left a similar complaint. They told me to read the manual and then go to a service center. They need to rename that section of the company. It is not what I consider "support."
    Basically they said: Good luck with that!
I have a homelite 350 automatic chainsaw. How can I get a repair manual for it?
http://www.mymowerparts.com/pdf/Homelite-Parts-Manuals-For-Chain-Saws/
May 02, 2016 | Homelite Garden
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Looking for homelite model 3374 chainsaw
Pull the handle back to free position.
Jul 12, 2014 | Homelite Garden
Trouble securing homelite clutch cover
If it has a chain brake it might have gone off(released)when taken off or put down. It would be a circular spring or other device which stops the chain when released. Pull back on the handle while holding the cover and it will hold back allowing you to put it back on.
Oct 06, 2013 | Homelite Garden
I just started up my new 16" Homelite and the engine starts, but the mechanism that powers the chainsaw isn't rotating... any suggestions?
The engine needs to be accelerated to make the chain turn. The chain should not be so tight on the bar that you can't turn it by hand. Make sure the chain brake is off by pulling back on the brake paddle which has a 'toggle' effect--it should snap over to the new position. If still having problems, it is time to return for warranty exchange or repair. Hope this helps!
Jan 09, 2011 | Homelite ZR10926 16" Chain Saw
I have a Homelite Chainsaw 45cc Power Stroke. Model No. UT10946D. The chain brake is always applied. Brake lever will not latch in the released position. I've disassembled it and do not see anything...
I have the same model (ut10946d) and used it for less than 2 tanks of gas when the chain froze. I noticed it was slowing down and it seemed like the chain brake was not disengaging and staying in the "unlocked" position.
I took the tool apart today and found that the band that rubs on the clutch to stop the chain was dragging on the clutch because it doesn't disengage all the way. The heat from the friction melted the plastic parts around the clutch housing and crankshaft. So now I have a chainsaw that I bought new, used for less than an hour, and is now junk due to poor design and/or product control.
I WILL NEVER BUY ANOTHER HOMELITE GAS POWERED TOOL AS LONG AS I LIVE. THEY ARE PURE JUNK!
My solution, call homelite and complain about it, maybe they'll stand behind their design flaws - but I doubt it.
Jun 18, 2010 | Garden
The brake won't fully release. It clicks and falls into place but the brake is still on unless you hold the brake arm back.
you need to take the side cover off as if you were changeing the chain,there has to be sawdust or the like jamming things up in there and you wont know what until you expose the problem area, do that , and then come back to me if you cant work it out but that is where the trouble lies
Nov 03, 2009 | Homelite ZR10926 16 Chain Saw
Ryobi pcn3335 chainsaw chainbrake will not release fully
1. Is there a Homelite/Ryobi dealer/authorized repair facility near you? If yes I'd try them they may repair it.
2. Any major chainsaw seller/repairer may be able to repair it... there will be a fee.
Lou
I own a few chain saws without chain brakes. I also own and use good PPE.
Feb 25, 2009 | Ryobi Garden
Fix bar brake on homelite timberman 45
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Oct 12, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
1,559 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
