Question about Transmission & Drivetrain for Mazda Tribute
Stalls takeing off
After taking off shifts fine
  • 60 Answers
Is the choke sticking or or fuel/air filter clogged?
Posted on Jan 22, 2013
Transaxle clutch wont release when hot stalls engine
Replace the Torque Converter Solenoid in
the transaxle
What you have is like coming to a stop with
a manual shift & not pushing in the clutch & it stalls
the motor
The converter clutch is staying locked & your
trans is connected to the motor
Feb 14, 2013 | 1995 Buick Century
2006 Jetta TDI Stalls in gear
These little engines(although very good little engines)have a problem with carbon build up in the intake manifold. It builds up so bad it begins to choke the engine off. The only solution is to remove the intake and soak with a good solvent over night and will generally take you a good couple of hours to clean out to get to "like new" again. Once this is accomplished, it's like driving your car new again!!
May 13, 2010 | 2006 Volkswagen Jetta
When I come to a stop my Sequoia stalls. When I put it in neutral or park it starts right back up, but as soon as you shift into gear it stalls. If I increase rpms then shift into gear will drive and...
Stalling is normally caused by a problem with
A) Lack of air - check your air filter
B) Lack of fuel - the fuel filter/fuel injectors get dirty
C) Lack of spark - inspect your plugs & wires
Might want to try cleaning the throttle body. Every 30k miles they should be cleaned.
Best bet however is to take it to a reliable, licensed mechanic. Vehicles 1996 & newer can have diagnostic codes read by a computer hooked up to the vehicle, identifying the problem.
Dec 05, 2009 | 2001 Toyota Sequoia
89 z24 stalls instantly when shifting out of park
Your lockup torque converter is bad I believe. When you shift from Park into any gear it will die.
Sep 17, 2009 | 1989 Chevrolet Cavalier
Transmission stalls when shifting
Sounds like the tranny needs to be rebuilt. Like the pressure plate and the disk are worn
Jun 02, 2009 | 2003 Chevrolet Impala
Truck stalls at stops
change the vehicle speed sensor,that has alot to do with shifting,the speedometer,and it will slam into gears as to shift from park to drive or reverse,and when it shifts gears.its about a $35.00 part
Jun 01, 2009 | 1993 Ford F250
Shifting in and out of overdrive and sometimes stalls out
check the fuel pump pressure,may need a new pump,if not then try changing the throttle position sensor
Apr 25, 2009 | 1998 Ford F150 Regular Cab
Car stalls after shifting into drive
ya need to have the code pulled,but sounds like a bad throttle position sensor
Mar 16, 2009 | 1996 Toyota Corolla
86 Grandprix it shifts gears to fast andI get no torque
get it scanned for soft codes.... likely a VSS (vehicle speed sensor) out or shift solenoids for trans
Dec 23, 2008 | 1986 Pontiac Grand Prix
Transmission & Drivetrain for Mazda Tribute Logo
47 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
JOHN LAPIER
Gary Nitowski
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
