Question about Klein Electronics BluComm M7 Bluetooth Adapter APX, XPR
M7 bluetooth adaptor will not pair with motorola apx 6000
Exits pairing mode before pairing
How do I connect my Motorola H720 Bluetooth headset to my PAnTECH P7040 cell phone?
Sharon-
Turn on Bluetooth on your pantech phone. Then H720 Bond Pair .
Mark
Motorola Support
Motorola Owners Forum
need help pairing my H70 Motorola Bluetooth with my Pantech P7040 cell...
Mar 08, 2015 | Motorola Mobility H720 H 720 Bluetooth...
I have a motorola bluetooth without the pairing code. Also I can not tell by looking at it what model it is ...it just says Motorola. it was my fathers and he can not find the book. Help I need it for work...
Bluetooth headsets have their pairing code hardcoded by their manufacturers. Most of them, choose '0000' (four zeros). Others choose '1234', whilst some of them use '8888'.
A bluetooth headset must be put in pairing mode, prior to its first connection to a bluetooth enabled device (e.g. phone, PC). All of them must be turned off before starting the pairing procedure. Some motorola headsets have a boom, which must be opened, in order for it to enter the pairing mode, whilst other headstets must have their Multi Function Button (MFB, or Call/End button) pressed and held for some 6 to 10 seconds. Their LED light use to indicate their pairing mode. Some of them flash rapidly (sometimes in more than one color), whilst others keep it solidly lit. Anyway, once your headset is in pairing mode, make your phone (or PC)'s bluetooth application search for new devices. After a while, your headset should appear on the device' screen. Select it and make the application connect. If a passkey (or PIN, or pairing code) is requested one of the codes I've suggested above.
The pairing procedure, between any two bluetooth enabled devices, should be done only once. All subsequent connections should be achieved by bring both devices, with their bluetooth radio turned on, close enough to each other. If their link is not automatically established, a simple press on the headset's MFB should be enough.
Hope you are able to pair your headset soon.
Regards, Carlos
Jun 02, 2010 | Motorola Mobility Bluetooth Hands Free...
Need instructions on how to pair bluetooth motorola H710 with blackberry curve
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Dec 25, 2009 | Motorola Mobility H710 Bluetooth Headset
How do i pair my motorola H390 bluetooth on a katana
Nov 03, 2009 | Motorola Mobility H390 Bluetooth Headset
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
How do i link up my H3 motorola bluetooth to my motorola i776
Jun 27, 2009 | Motorola Mobility Bluetooth Headset H3...
I can't pair my motorola h681 bluetooth and my SGH -A837
Jun 08, 2009 | Motorola Mobility H550 - Bluetooth Headset...
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 12, 2009 | Motorola Mobility Universal Wireless...
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
How to pair a Motorola D200 to a phone??
You will never be able to pair the d200 to a phone or another device, for this is a a2dp bluetooth dongle, that´s why it works with your headphones.
Mar 07, 2008 | Motorola Lands Phones
Klein Electronics BluComm M7 Bluetooth Adapter APX, XPR Logo
132 people viewed this question
Top Klein Electronics Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Klein Electronics Radio Communication Expert? Answer questions, earn points and help others
