Question about Life Fitness Treadmill Precor C954 (Used)
I have a reconditioned Precor C954. It has been sitting unused for at least two years. I plugged it in and the fan on the motor turns on, however the console does not light up. Perhaps a fuse issue?
The unit has not been used or even turned on for at least two months. It is in a garage where during the winter temperatures drop down below freezing.
  • Life Fitness Master
  • 914 Answers
You can start with checking the fuse, but I would also verify the correct voltage is making it to the lower board. Start at the wall outlet and follow the power through the cord and through the on/off circuit breaker. If you are getting power to the lower board and not to the console up top, it could be one of a few things. It could be the lower board, the wiring from the lower board going to the console, or the console itself. You will need a multimeter in order to do the proper troubleshooting. I will attach a link where you can view the service manual for your machine. There will also be a link to a video on using a multimeter.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Generic%20Service%20Manuals/COMMERCIAL%20TREADMILL%20GENERIC.pdf
Video about Multimeter Testing
Posted on May 09, 2014
I recently bought a used Precor 954i it worked fine then when i brought it home and wired it in with a 20amp breaker and 240 volt im getting error 29 as soon as i turn the machine on any ideas?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29 Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Sep 22, 2015 | Precor 954i Experience Series Treadmill...
Treadmill keeps stoping
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
My treadmill stops wen runing on it and brings up er 27 on screen
Corrective Action
My treadmill stops wen runing and brings up er 27 on screen
Corrective Action
Precor treadmill code e3 is on
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
I have a precor c956i and got error 27 on it, what can i do to resolve probmem? thank you
Corrective Action
Sep 27, 2013 | Precor C956i Treadmills with HR /...
What is error 28
Precor Error 28, Temperature Too High Probable Cause 1. The lower PCA cooling fan is clogged.
2. The lower PCA cooling fan is inoperative.
3. The running belt and/or deck are badly worn.
4. The lower PCA is bad.
5. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Inspect the fan mounted on the lower PCA for dust/debris buildup. Clean if necessary, ensuring the fan spins freely. Some lower PCA's do not have a cooling fan and others may have the fan mounted on the underside of the lower PCA making it not as visible.
  2. The fan was free of dust or debris but does not spin. Make sure that the fan wiring is secure and properly connected to the lower PCA. If no obstruction to the fan and the wiring is good but fan still doesn't turn, replace the lower PCA.
  3. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions; compare the values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  5. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 28
Sep 13, 2013 | Precor C966i Treadmill C 966i
What os the meaning error 42, 49, 45 on the treadmill C954?
This erron had implies with the elevation motor.
Please RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
Jun 08, 2012 | Precor C954i Commercial Treadmill
Upon powering up my precor treadmill goes straight to the highest incline
hi,
Your treadmills motor controlling circuit have some problem. thats why you cant adjust its speed. its running at its high speed because its motor controlling IGBT become shorted. As these potion of your treadmill is a high voltage point, i will recommend you to consult the manufacturer for support.
ok
Jun 07, 2011 | Life Fitness Treadmill Precor C954 (Used)
I just bought a reconditioned C956 model. The
hat sound is due to the bearing failing inside the motor this is cause by capacitance discharge thru the armature thru the bearings. these unit can be rebulit I 've done plenty
Apr 13, 2010 | Precor C956i Treadmills with HR /...
Life Fitness Treadmill  Precor C954 (Used) Logo
61 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
