My nakamichi over the ear headphones don't work. only the right side works, and the part where the cord attachs to the headphones are slidy.
The part where the cord goes into the phones has that little metal part, and mine slides in and out which may be the source of the problem
  • dude that stinks Jan 20, 2013
    Actually, they were only likethirteen bucks so I'm just gonna return them.thanks anyway
  • 537 Answers
SOURCE: No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Posted on Nov 21, 2007
  • 50 Answers
SOURCE: Bose in-ear headphone cord cut
most head phones there two wires. those are the two that you most likly put together. if there is any metel mesh covering the wires. that has to be connected also.
Posted on Jun 20, 2008
  • 11 Answers
SOURCE: Right Bose In-ear cord separated from headphone
i know that these are very exspencive headphones, they were 100 dollars, and they are great. unfortunitally, these cannot be fixed without getting new headphones, sorry!!!
Posted on Aug 27, 2009
SOURCE: Right ear bud isn't working
i have this problem too, except it's the left side that doesn't work. i think that's because the copper wire inside broke or is severed partly. there is no way to fix it... just go buy a new one and this time try to kot coil the cords around hour mp3or ipod.
Posted on Oct 28, 2009
  • 1138 Answers
SOURCE: I am only getting sound out of one side of the in
Here is a link to how to do it:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/ Let me know if this helps.
Posted on Nov 30, 2009
Boss oethe left side of my headphone is stop working
The most common cause for this, is a loose wire connection to that speaker (as opposed to the speaker being faulty).
Has anyone pulled the cord too tight or tripped on the cord? If yes, then the internal wire connecting that speaker has an internal break somewhere.
Try the following:
1) Plug headphones into music device and turn on.
2) Gently press the wire 'in' at the left earpiece (or wiggle at the earpiece end). If sound returns intermittently, then you have n internal wire break in that end of the cord.
3) Gently press the wire 'in' at the plug where it connects to your player (or wiggle the cord at the plug end). If sound returns, then there is an internal wire break at this end of the cord.
In the case of broken internal wires, it is possible to repair.
Although very fragile, it is possible to resolder these tiny wires (you'll have to burn off the enamel coating around these wires first) back onto their respective connections, or onto a new plug.
Good luck....
Jan 13, 2012 | Bose On-Ear Headphones
I have the sennheiser cx 380 orange sport in ear headphones. The cord where it attaches to the metal plug has pulled apart in a way that the metal plug can pull away but the cords are in tact. And now the...
I think this is common problem for headphones. To fix it you will have to solder cord's wires back to plug. If you have tools and some experience you'll be fine
Aug 17, 2011 | Sennheiser Audio Players & Recorders
I have Bose in-ear headphones with remote. I use them during my workouts and I think the sweat has damaged the remote that's on these headphones. The remote has stopped working and it erratically...
Ayish DX,
If you just want to get rid of the remote control functionality, you could simply replace the cord for your headphones. This may be a little difficult to do, but it is possible. Do keep in mind though that you have purchased a Bose product, and unless they have changed lately, they provide a lifetime warranty on almost all of their products. you may be able to send off for a replacement pair! if this is the case, don't make any modifications at all, as you will void the warranty.
~Kudos~
May 03, 2011 | Bose in-ear headphones - Black with...
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
I am only getting sound out of one side of the in ear headphones. if I wiggle the cord just right I can hear sound from both sides. Can this be repaired?
Nov 30, 2009 | Bose in-ear headphones - Black with...
Oct 27, 2009 | Bose on-ear TriPort Headphones
Mar 17, 2009 | Bose in-ear headphones - Black with...
Jun 05, 2008 | Bose in-ear headphones - Black with...
No sound on right side
I had such a problem, but I fixed it.
Plase see video on YouTube:
or read this brief text explanation:
Under/behind the ear sponge are four screws - 3 black screws, that holds ear cup closed, and one silver cup, that mounts small piece of plate, that holds the cord.
Gently unscrew, open ear cup, and then first I suggest to check if circuit on that small circuit board is not broken! You can also check wires, etc.
DawidWarsaw
Mar 12, 2008 | Pioneer HDJ-1000 Professional Headphones
384 people viewed this question
 Grubhead
Grubhead
