Question about Craftsman Garden
Need a blue print to show how to reassemble blower
I need a drawing so I cqn put blower back together
2 Suggested Answers
SOURCE: putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Posted on Oct 11, 2008
A piece of paper was stuck. In freeing it, I removed a long piece of blue plastic. I cannot get it back in, and manual shows no detailed drawing of the underside of the top/lid section of the printe
Take a tape measure, measure the exact length of the unit removed. Then check the ends if there are slots or notches so that you can compare and contrast about measurements and shape for insertion. Position the shape to the expected considerable place and you will succeed.
Dec 27, 2014 | Office Equipment & Supplies
Pole saw
I remember the first time i dismantled one too.. :) Pain in the but if you dont know where bits go.
Here is a link to the IllustratedParts List, showing the complete breakdown drawings. Good luck
Jun 12, 2013 | Garden
In my 1996 GMC sierra 2500, the heat cuts out.. i will put it on high it works for a second then turns off. i have also noticed that when it does cut out the lights on the PRND321 goes out as well. i...
The heat cut's out ? The heater blower motor stops working ? Testing the electrical circuit would be the proper way to diagnose . Looking at a wiring diagram an using a DMM - digital multi-meter , an doing amp draw test on the blower motor . The PRND321 an blower motor probably share a ground or power point . Looking at a wiring diagram for both circuit's would show that . Not a short , more likely a loose ground connection . Free wiring diagram's here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size . Under system click on HVAC then under subsystem click on HVAC controls . Then click the search button ,then the blue link . First blue link is blower motor control circuit . Voltage drop test the blower motor ground .Videos on youtube showing how to diagnose !
Blower Motor Resistor Replacement Wire Splice Splicing Amperage Draw Test
Blower Motor Resistor Function and Diagnostics
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Oct 30, 2017 | 1996 GMC Sierra
THE PLASTIC BLOWER BAFFLE ASSEMBLY SEEMS TO HAVE DISENTIGRATED AND MELDED ON CASING OF BLOWER. I NEED PART # AND REASON WHY THIS HAPPENED
Hi Byron, there are a couple of versions of the Kawasaki #KRB750B backpack blower, so please check the first link below to get the parts list for your model. I've looked up a couple and the 2nd link below shows what I've found on the Kawasaki website for parts for these units.
Select model number from this list:
http://kmcb2c.econnect.partsandwarranty.com/kmcb2c/Menu?action=CATALOGB2B&chID=302125&elementType=1&historyDepth=-1&CHANGENUMBEROFITEMS=63
Here's one of the exploded drawings with parts available, etc.
http://kmcb2c.econnect.partsandwarranty.com/kmcb2c/Menu?action=CATALOGB2B&prodID=3169045&elementType=2&historyDepth=2&CHANGENUMBEROFITEMS=63
Once you've confirmed the model variation you've got, you can then contact either a local Kawasaki dealer or check the internet for a supplier that can sell you what you need.
As far as taking the unit apart, make sure that the gas is drained into a gas container and then allow it to stay vented before you begin taking the blower apart. My suggestion is to take a picture with either your digital camera or camera phone, of the unit BEFORE you start taking things apart and at EACH step as you remove a part (screw, etc.) so you'll be able to refer back to those pictures when you start to reassemble it. That and the line drawings at the above links, will make it much easier to recall just where each part goes and how it went together.
You can also use the Dealer Locator feature on the Kawasaki site to find one near you, or to call and place your parts order, etc.
By the way, I did read your question and noted that you DID put in the brand and part number for your blower, so thank you for providing enough information to help me resolve your problem!
I hope you find this Very Helpful and best regards!
Nov 04, 2009 | kawasaki Krb750b Backpack Leaf Blower
The Blue ink is not coming through despite multiple deep cleanings (it will help for about 1/3 of a page and then revert). I have reset the print head, tried two new cartridges, powered off for awhile and...
put it in warm water, i mean the print head. Leave it for 5 - 10 minutes.
Dry it, put it back, draw a blue square, and print it. If it started to print a little repeat the procedure with the water
Jul 31, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Mar 19, 2009 | Garden
Reassembly of Auger Housing
If you go to www.mtdcanada.com you should be able to find aparts breakdown for your machine which will be helpfull in puting it back together.You will need your model and serial # to find your parts breakdown. The breaedown wont tell you how to do it but it will give you a good idea. if it's not helpful the if you post the model and serial # here then I can see what you will need to do.
Dec 21, 2008 | Toro Blowers Rake and Vac - Electric...
Putting back together a poulan 1500le leaf blower
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
I need to reassemble a crossman airgun model 760-D
i need a website adress or link to a understandable diagram of how it goes together
Mar 12, 2008 | Crosman (4032)
Science
this is the drawing to plan something for example a house.
Dec 29, 2007 | Video Game Consoles & Games
Garden Logo
16 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
