Question about Home Security
Need manual for garage door opener HBW1136
Stopped working. Changed batteries but it doesn't work
  • 6 Answers
SOURCE: manual
I would try here, they seem to have library of manuals.
http://userguides.50webs.com/
Posted on May 26, 2008
SOURCE: Garage Door Remote Not Working Consistently
Lift Master Security Plus remote works only intermitenly, It seems to lock after a few tries, Works from inside garage, Seems to lock up after few tries, Wall opener fine. Changed batteries several times. Can't understand why it works and then doesn't. Tried cleaning sensors and wires,
Posted on Oct 29, 2008
  • 244 Answers
SOURCE: Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Posted on Jan 15, 2009
SOURCE: My Chamberlin remote garage door opener stopped working.
Try this website for a possible solution
http://www.bearcatco.com/helpgifs/liftmaster_troubleshooting.html
Posted on Feb 16, 2009
SOURCE: Garage door opener won't work
you should have installed a emergency key release !, it,s a cylinder that you put a key into and pull out a cable thats attached to your emergency release inside the garage , right now you would have been in already , but since you never installed one lets deal with the problem at hand , answer me this : do you have power inside the garage ,are you certain that the breaker is on ,did you have any recent power failures ?, because the circuit board on your machine could be fried from a close lightning stike , and i,ve seen it a thousand times , also your capacitor on your machine may be shot ! is your door wood or steel? if its wood drill out a 3 inch hole saw hole on the top panel either to the left or right of the center wooden cross member , now get a flashlight and look for a emergency relese rope , after you have located it,make yourself a coathanger with a hook at the end ,tug at the rope until your able to pull at the handle thats attached to the rope once you are able to release the door from the carriage assembly keep pressure on the handle and have someone else lift the door and when you want to fix the hole you made just simply glue the circle cutout back in place , good luck and do what i say to get in , please leave a nice rating if i was able to help you ,sincerely glenn
Posted on Mar 06, 2009
The garage door remotes and keypad works only when i,m very close to opener, will not work at more then 6 ft away from opener. sears hbw0777
How old are the batteries in the remotes and keypad? Replace the batteries. If that helps, then you have solved the problem.
If it doesn't help, then check the antenna wire of the opener. (Make sure it is extended down from the unit.) Note this doesn't apply to all garage door openers. (We have several models - some with the external antenna and some without.)
Does your garage have metal walls and metal doors? This can shorten the range between the receiver and the remotes or keypad. An antenna extension may be available.
I don't see the HBW077 as a model number at Sears Parts Direct or Manage My Life. Please check the model and let me know if I can provide any additional assistance. (Sears Parts Direct has parts for my garage door openers. Manage My Life has manuals for Craftsman and Sears appliances.)
I hope this helps.
Aug 04, 2011 | Garden
Have to hold button in on remote and keypad for door to go up and down changed battery on keypad but problem still occuring please help
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Jul 30, 2011 | liftmaster 371 Remote Transmitter
I have a garage opener where the remote is not working. I have changed the battery, but it is still not functioning. Craftsman FCC ID HBW1136
Make sure the light in the wall control is not blinking. If it is press and hold for 3 seconds the button with the lock icon. If this isn't the case your remote may have failed.
Dec 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
212 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
