Hitachi HA01234 Lamp Ballast EUC 120 P/11, 9137 008 11474 Logo
A
Anonymous Posted on Jan 19, 2013
Euc 300c p/11 - Hitachi HA01234 Lamp Ballast EUC 120 P/11, 9137 008 11474
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on Apr 02, 2015
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197689
Points
977
USD50 for the ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
2008 Chrysler 300C. Where is the location of the fuse for the cigarette lighter?
Cigar lighter (power outlet) fuses in the Chrysler 300 / 300C are the fuses ?9 (Console Power Outlet), ?16 (Power Outlet Trunk, if equipped) and ?18 (Selectable Power Outlet) in the Rear Power Distribution Center (in the trunk).
Chrysler 300 / 300C (Mk1/LX; 2005-2010) fuses
Fuse-Box.info https://fuse-box.info > chrysler > chrysler-300-300c-m...
Here you will find fuse box diagrams of Chrysler 300 / 300C 2005, 2006, 2007, 2008, 2009 and 2010, get information about the location of the fuse panels ...
Which fuse is used by the courtesy lights in a 2008 Chrysler 300C?
2008 Chrysler 300C. It has no turn signals, no wipers, no high beams.
Question edited for clarity and add maker.
Question moved to model category. There are 4 versions of the 300C including the SRT version.
The first step would be to check the fuses covering those items
Fuses and relays box diagram Chrysler 300
fusesdiagram.com https://fusesdiagram.com > Chrysler
Fuses and relays box diagram Chrysler 300 2004-2010. Identifying and legend fuse box.
Chrysler 300/300C (2005 - 2010) - fuse box diagram
Auto Genius https://www.autogenius.info > chrysler-300-300c-200...
Jan 14, 2021 - Chrysler 300/300C (2005 - 2010) - fuse box diagram. Year of production: 2005, 2006, 2007, 2008, 2009, 2010. Luggage Compartment Fuse Box.
My 2006 Chrysler 300C sits very low, how high should it be?
06 Chrysler 300 AWD
front-- 13 15/32 to 14 1/4 inch
rear-- 11 3/4 to 12 1/2 inch
2answers
I have a 2007 300c awd hemi. i had the check engine ight come on. google said to pull the number 11 fuse now the car wont start. do i have to reset the computer
Did you put back. Pulling a fuse will not reset the light you have a problem the only way to do that is find out what is wrong. I think starting problem was caused by pulling the fuse. Put fuse back and give me an update
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
How do I remove the arm and install a new arm on a Chrysler 300c 2006? Do I have to remove the strut?
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????11
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
