You may want to have a qualified technician at one of our Authorized Service Centers clean your machine.
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
SOURCE: Bissell carpet cleaner
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
SOURCE: My Bissell PowerEase carpet cleaner
Unlatch the cannister according to the directions, you will see a meatal latch, unhook it slide off Power nozzle, rinse it off, pull lint, hair off brushes, reassemble
Here's a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1188&cid=ccsocial
If you continue to have problems, here's a link to locate one of our Authorized Service Centers.
