Question about Sunbeam Instant Steam Food Steamer & Rice Cooker With Instruction & Recipe Book
Where does the water go for instant steamer
I don't have a manual or a box for it, where the hell does the water go?
I just was given a Eureka Enviro Steamer model 370A. I don't have an owners manual, & I plugged it in, light came on, but no steam. Nothing! Help!
click the link below for manual
http://static.fixya.com/Manuals/E/Eureka/nvr_Stmr_370_C3B7174F51D011C6ACD46F513524BC9D.pdfhttp://static.fixya.com/Manuals/E/Eureka/nvr_Stmr_370_C3B7174F51D011C6ACD46F513524BC9D.pdf
Sep 06, 2013 | Vacuums
How much water to how much rice
I don't usually steam rice, but cannot imagine you need to concern yourself about the precise quantity of water.
I would use 2 - 3 ounces of rice per person, that is between about 50 and 80 grams and plenty of water, say 2 pints or about 1 and a half litres as long as your steamer takes that amount of water.
Aug 28, 2012 | Kitchen Appliances - Others
Hello, I don't have an instruction manual
To get the instruction manual,
1. Ensure you have an Adobe PDF reader on your system,
2. click on this link below
3. Click on "download" on the 3 in 1 rice cooker and you have your instruction manual on your system, all you have to do is print it out.
http://www.tefal.co.uk/tefal/Consumer_service/Use_instructions/HomeUseInstructionsTemplateFile.aspx?NRMODE=Published&NRNODEGUID={33C4DFFB-BA1F-42FE-8BFE-1EF29DBF3A9E}&NRORIGINALURL=%2fConsumer%2bservice%2fUse%2binstructions%2fuse-instructions_home.htm&NRCACHEHINT=NoModifyGuest
Sep 09, 2011 | Tefal 3 Tier Ultra Compact Steamer Rice...
I am trying to upload manual for 6c rice cooker and steamer, I just purchased it and there was not one in the box. Doesn't seem to want to load, can you email it to me .
A manual for the Rival RC61-CNcooker which is identical and made by Black and Decker is at:
http://www.rivalproducts.com/manuals/MANUALS/RC61_43_53194273.PDF
Sep 07, 2011 | Black & Decker Black Decker RC3406 6Cup...
Hi I have a kenmore front loader quite pak 9, that keeps giving me a f35. I don't konw where my manual is. PLEASE HELP ME!!!!!!
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
May 13, 2011 | Washing Machines
Every day or 2 I have to mop up water on the freezer side of my side by side. it is about 10 years old now.
sounds like the drain is blocked.you might have to remove the inside back panel in the freezer but look at the bottom of the panel,if you see ice there,there's a drain hole under the ice,melt it out with a hair dryer then you have to clear the drain,i use a steamer to do this,i stick the nozzle into the hole and the steamer blasts through whatever is in the hole,if you don't have a steamer you can try to melt the ice and then blow hot air into the hole to melt the ice down in the drain,then use a turkey baster or anything that will blow into the hole,when you think the drain is clear pour hot water into the hole,if it goes down the hole it's clear if not keep hitting it until the water goes down,watch out trying to snake anything into the hole,the lines are plastic,you can try a plastic tie to snake down the hole.if the drain isn't blocked check to see if one of the water lines are leaking from under the fridge or you could have a problem with the ice maker but you'll see ice forming from that,,good luck.
Apr 12, 2011 | Admiral Refrigerators
Box didn't contain instruction manual..how to use Oster #4722 rice steamer. Please help!
Here is a tip that will help you figure out about using a rice cooker...
How much Rice and Water go in the Cooker
heatman101
Jan 29, 2011 | Oster Kitchen Appliances - Others
Rival automatic steamer rice cooker 4450 guide needed
Here's all the info I've been able to find:
The older Rival rice cooker steamer should have a base, a lid, steamer basket, and rice bowl.
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Timing is Everything
Whether using the Rival Steamer for a main dish or for a side dish, cooking is easy. But not Fast. Rice and steamed vegetables actually take twice as long to cook in this steamer. The simplicity comes since you add your rice or vegetables in one step. No waiting for one thing to happen before you can do the next. Put water and fruits, vegetables, fish, poultry or rice in the basket or bowl that come with the unit, cover, plug in and wait for the light to go off per the timing chart.
1/4 cup water takes 6 -7 minutes
1/2 cup water takes 10-12 minutes
3/4 cup water takes 16-17 minutes
1 cup water takes 19-22 minutes
1.25 cups water takes 24-26 minutes
1.5 cups water takes 26-30 minutes
2 cups water takes 38-39 minutes
2.5 cups water takes 43-44 minutes
3 cups water (max fill) takes 45-50 minutes.
Steamed Chocolate Pudding (From the Rival Steamer Guide)
3/4 cup flour
3/4 teaspoon baking powder
1/4 teaspoon salt
1/3 cup butter
1 teaspoon vanilla
1/2 cup sugar
1 egg, beaten
1.5 ounces unsweetened chocolate, melted
1/2 cup milk
1/4 cup chopped nuts
Sift together flour, baking powder and salt; set aside. Cream butter and vanilla until fluffy. Gradually add sugar, beat well. Add egg and melted chocolate; blend well. Add milk alternately with dry ingredients and beat until smooth. Fold nuts into batter. Pour into greased 8"x4" loaf pan. Cover pan with aluminum foil. Place pan in steamer basket. Cover and steam until wooden pick inserted near center comes out clean. Serve warm with **Marshmallow Cream Sauce. Water: 1 cup. Time: 19-22 min.
**Marshmallow Cream Sauce:
16 large marshmallows
1/3 cup cream
In a small saucepan, combine ingredients and melt over low heat. Serve over Steamed Chocolate Pudding.
Feb 23, 2008 | Rival Automatic Steamer/Rice Cooker 4450...
Sunbeam Instant Steam Food Steamer & Rice Cooker With Instruction & Recipe Book Logo
21 people viewed this question
Top Sunbeam Dishwashers Experts
Are you a Sunbeam Dishwasher Expert? Answer questions, earn points and help others
